either way, a car with correct tuning can be run without a maf Sensor.
unless i am off on that.
stock map maxs out at 100 kpa, you could add a GTP sensor (if it even fits in the upper intake) and run to 140 kpa witch will add fuel untill about 7PSI
the only way to add fuel is tuning PE and it IS EXTREAMLY HARD, and you have to retune almost weekly.......
plus i didn't see anywhere that you have HP Tuners to even tune the car
I own HP Tuners and Access to DHP, so i have plenty of tunig ability, and 14-15 psi is track only, there wont be any DD of this, so I am not concerned about tuning when I go to the track, its a 30 min drive out there, scan, adjust, drive, adjust, then run.
accualy it will be more like tune after each run down the track....... you need a WB for the car to log with......
BTW i DD'ed 18 PSI for 2 months....... not a big deal just have to tune it and DD'ed 14psi for like 8 months
well i am gonna take the car eslewhere for the original tune.
I dont trust my skills with a brand new turbo, and now what looks to be a new bottom end. I will get a abse tune prolly in Chicago, Speed Inc. and then I will go from there.
