Computer Help: - FirebirdV6.com/CamaroV6.com Message Board
Computer Help:
  • Computer Help:
    I'm not having too much luck putting together this PC for my girlfriend's dad. Here's the story.
    I put the computer all together, everything worked fine except the CPU was running hot. So I tried to work that out, and while I was doing that, BAM, the power supply blew up. I RMAd the case, they sent me back a new one, and now when I turn on the computer, all the fans spin but I get no video, and no beeps.
    Please point me in the direction of what to RMA next. I need to get this computer up pretty soon.
    1 G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL4D-2GBPK
    1 Intel Pentium D 950 Presler 3.4GHz LGA 775 Dual Core Processor Model BX80553950
    1 Seagate Barracuda 7200.10 (Perpendicular Recording) ST3250620AS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive
    1 GIGABYTE GV-NX73L128D-RH Geforce 7300LE Supporting up to 512MB(128MB on board memory) by TurboCache technology GDDR2 PCI Express x16 Video Card
    1 SAMSUNG 18X DVD±R DVD Burner With 12X DVD-RAM Write Black E-IDE/ATAPI Model SH-S182D
    1 ASUS P5B Socket T (LGA 775) Intel P965 Express ATX Intel Motherboard
    2002 Silver Metallic A4 Firebird - All Options
    Hotchkis STB, Custom Madrel Bent 3" Exhaust, Pacesetter Headers, Whisper Lid, FT Ram Air, K&N Air Filter, D2S HID, Baer Rotors, !EGR, !MAF, 10% tint, Parrot CK3300
    Your Mom or My Dad?
    Re: Computer Help:
    if possible, you may want to try a different video card, or just clean the connectors and make sure it's seated properly..I had almost the exact same problem, the video went after my psu blew. Depending on what case you got (quality of the psu) you might want to try a better one.
    chances are if the powersupply blew out, it took your motherboard with you. And if your motherboard went with it, chances are things like the cpu, ram, video, might all be dead. I would probably start with the mobo.
    1996 Chevrolet Camaro
    1995 Buick Park Avenue Ultra
    --Appearance Moderator--
      Re: Computer Help:
      The jumpers on the motherboard might be set to "clear CMOS". You may need to change the jumpers from "Clear CMOS" to "Normal". Read the motherboard book, it comes in very handy. Other misc. problems:
      Make sure all cards are pushed all the way down
      Make sure memory is all the way down;
      Make sure that you did not bend a pin on the CPU and make sure it is all the way down
      Make sure the CPU fan is attached properly
      If you are using an AGP or PCI-E video card, if the motherboard has an on-board vid. card, use that one first and see if you get video. If you do, go into the BIOS and make the necessary changes so that the AGP/PCI-E is the primary video adapter.
      Worst case scenerio, you might have fried the CPU or other components if you have too much static electricity and caused an ESD on the chips.
      I hope this helps.
        Re: Computer Help:
        Ya, most likely is the PS went, it may have fried everything else as well. So, I'd see if you could RMA just about everything......that sucks man........
        ~97 3.8L V6 Camaro~
        A few things
        Only Member of Team Hooker?!?
          Re: Computer Help:
          I was going to try to troubleshoot it, but I went ahead and just sent it all in. Newegg is pretty good about that stuff.
          Your Mom or My Dad?
            Re: Computer Help:
            Yes they are. Just tell them the PS went, and took everything with it. They'll RMA EVERYTHING! Which is awesome. I don't buy anywhere else but newegg (unless it's something small and cheap, or something I need ASAP).
            ~97 3.8L V6 Camaro~
            A few things
              Re: Computer Help:
              sounds exactly like what my desktop computer did about 6 months ago. power supply pooped out and took the motherboard with it. not worth the repair....and damnnnn the setup you had was nice too
              Black 1996 3.8 Firebird T5, SLP CAI, Pacesetter Ceramic Headers,160* t-stat, PCMforLess Tune, Flowmaster American Thunder catback, Car Sounds Cat, custom s-pipe, MSD coils and wires, NGK plugs, 3.42 posi rear, B&M Ripper, 245/50 BFG-G-force's
