Update on my project. - FirebirdV6.com/CamaroV6.com Message Board
  • Update on my project.
    It's been a while since i've posted. I figured some poeple might be curious on how it's coming.
    all parts are in and Abbott racing heads is in the process of building the engine. I hope to get it in a few weeks.
    Patrick<br />Sick Sixx Member<br /><b>97 Mystic Teal Camaro</b><br />425RWHP @14PSI<br />Old setup:<br />330RWHP @7PSI 13.9 @ 106.6 <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=4\" target=\"_blank\">Mods</a>
    Re: Update on my project.
    Pretty sweet. How much are you looking to put to the ground after all this?
      How much was/is everything costing? We had a brief discussion on your car in the FI section. I was wondering what it ran with the stock motor and only the FFF kit (without intercooler). ?
      2004 CE Corvette 10.86@132mph
      2011 Cadillac CTS-V
      2006 Mitsubishi Eclipse GS
        My goal is 600 + RWHP....
        Intercooled:
        My first runs on 7 PSI (due to the MAF cutout issue) were not great; mostly because it was my first time at the track as well. I ran 13.9 @106 and a 2.43 60ft. After we could tune past the MAF issue, on 12PSI I ran a 13.0 @ 109 and a 2.1 60ft (with 4-6 degrees of KR bad tune).
        http://www.fquick.com/videos/viewvideo.php?id=215
        I can't share the cost but I will tell you it's over 5K. Here's what the new engine is going to look like. You can see every mod in the link below. I copy and pasted the engine below that.
        http://www.fquick.com/garages/viewvehicle.php?id=930
        L32 rods
        Diamond Pistons rings and pins
        cometic gaskets
        ARP Rod Bolts
        ARP Main Studs
        Comp Cam: 218/218 528/528 114
        Comp 918 Valve springs
        Comp. Push rods
        Titanium retainers
        Comp OE lifters
        ARP heads studs
        Bore
        fully ported heads and intakes
        Hone
        Deck
        Install cam bearings freeze plugs and block balance shaft oil hole
        Balance crank rods and pistons
        Turn crank
        160*
        65LB Mototron injectors
        SLP MAF
        Taylor wires
        TR-6's
        MSD DIS-4 Plus
        Patrick
        99 NBM Corvette
        02 4x4 Metalic Gray Tahoe LS
        01 NBM GTP--> For sale
        Motor current being built by Abbott racing Heads
        13.0 @109 2.1 60ft
        Mods
          mine looks better !!!! :banana: :tup: :tup:
          hehe we should get them about the same time i think but you will have yours installed firts cuase you got help :(
          www.turbov6camaro.com
          1997 3800 Series II Camaro
            Intercooled:
            L32 rods
            cometic gaskets
            ARP Rod Bolts
            ARP Main Studs
            Comp. Push rods
            Titanium retainers
            Comp OE lifters
            ARP heads studs
            Bore
            Hone
            Deck
            Turn crank
            160*
            SLP MAF
            Taylor wires
            TR-6's
            MSD DIS-4 Plus
            Patrick
            99 NBM Corvette
            13.0 @109 2.1 60ft
            Mods
            Cool, thanks for the info. And best of luck with the setup! :)
            2011 Cadillac CTS-V
              $#!T nice!
              '95 3.8L A4 PGM. & '95 LT1 M6 PGM. :burn:
                Linxs FTW!
                Matt<br />2000 Firebird<br /><br /><a href=\"http://www.fullthrottlev6.com/forums/index.php?\" target=\"_blank\">FullThrottleV6.com</a>
                  hmmm, not sure my motor will make it to 600, but I sure as hell will try, nice set up.
                    Looking good man, keep us updated :tup:
                    Black \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
                      nice!!!
                      Follow me!
                      Or this
