How much was/is everything costing? We had a brief discussion on your car in the FI section. I was wondering what it ran with the stock motor and only the FFF kit (without intercooler). ?
Pretty sweet. How much are you looking to put to the ground after all this?
My goal is 600 + RWHP....
Intercooled:
My first runs on 7 PSI (due to the MAF cutout issue) were not great; mostly because it was my first time at the track as well. I ran 13.9 @106 and a 2.43 60ft. After we could tune past the MAF issue, on 12PSI I ran a 13.0 @ 109 and a 2.1 60ft (with 4-6 degrees of KR bad tune). http://www.fquick.com/videos/viewvideo.php?id=215
I can't share the cost but I will tell you it's over 5K. Here's what the new engine is going to look like. You can see every mod in the link below. I copy and pasted the engine below that. http://www.fquick.com/garages/viewvehicle.php?id=930
L32 rods
Diamond Pistons rings and pins
cometic gaskets
ARP Rod Bolts
ARP Main Studs
Comp Cam: 218/218 528/528 114
Comp 918 Valve springs
Comp. Push rods
Titanium retainers
Comp OE lifters
ARP heads studs
Bore
fully ported heads and intakes
Hone
Deck
Install cam bearings freeze plugs and block balance shaft oil hole
Balance crank rods and pistons
Turn crank
160*
65LB Mototron injectors
SLP MAF
Taylor wires
TR-6's
MSD DIS-4 Plus
Patrick 99 NBM Corvette 02 4x4 Metalic Gray Tahoe LS 01 NBM GTP--> For sale 97 Mystic Teal Camaro
Motor current being built by Abbott racing Heads
13.0 @109 2.1 60ft Mods
Intercooled:
L32 rods
cometic gaskets
ARP Rod Bolts
ARP Main Studs
Comp. Push rods
Titanium retainers
Comp OE lifters
ARP heads studs
Bore
Hone
Deck
Turn crank
160*
SLP MAF
Taylor wires
TR-6's
MSD DIS-4 Plus
Cool, thanks for the info. And best of luck with the setup! :)
