Got my car retuned with some cams. Darin from Titan Motorsports did a hellof a job tuning my car. Compared to other Supra's I have a fairly small turbo which is a 66mm. I actually lost some horsepower due to my cams being too big for the turbo I am running....if I went with a bigger turbo id gain more HP on the same boost level.
Ill be able to make whatever my injectors will handle......800-830. If I put 1000cc injector Il be able to make 900-975 but i see no point in going that much. Ill stay in the 7-775 range.
Past Ride
1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
(If you dont know me, you haven't had a V6 long enough)
its a superahhhhh. it never gets to the ground :p j/k shane
want to frum roll?
nice numbers, should have video taped it i would have liked to watch it. really impressive car, keep it up. reading the "21PSI = low boost" made me smile,thats gotta be nice.
Wow! that's a lot of HP and torque........i'm just curious....How do u get traction? .....when you are pushing numbers that high, it's really hard to get traction.....right??................. :)
Technology is ur friend. I have a AEM standalone computer which i can control everything. I have one of the best tuners in the world tune the car. The way its set up is boost by gear......1st gear starts at a lower boost and 2nd gets higher and so on and so on. Its setup so I have traction in every gear. :)
Past Ride
