So, it's alright for the tiny metal pieces to go through the engine? I would think it has to be doing some kind of damage, very minute, but possibly something in the long run. I guess you could never be too protective and just use the Filtermag and the magnetic oil plug.
I was just curious as to if anyone used this on their cars. Because I wanted some real testimonials before I spent that kind of money just for a magnet.
the thing with the oil pan magnet is it is not powerful enough to pull the metal from a far, only what passes close close by. the oil is funneled more at the filter and If this is really powerful enough, it should work. I wonder if it causes basically clogged in the filter though...???
personally, I want something strong in the pan so it doesn't make it to the pump just cause. there are millions of cars running around with these particles including mine and all of yours....it doesn't destroy an engine that quick.
I'll do some more reading on this and see what I can find. I will let you know if I see any mentioning of it clogging or possibly helping to prevent possible clogging issues (I actually think I saw something to that affect, but I could be thinking about something totally different). Whatever the case, I'm on top of it, to get the scoop.
I've not tried one yet, but I probably will in the future, once I get my engine built. From the reports I've read, they create a much stronger magnetic field than the tiny magnets on the drain plugs do. And since the oil in the filter is much closer the magnet, its bound to work better. There is the problem of these particles going thru the pump. However, these magnets are designed to catch the stuff too small for the filters to get, so those particles would normally be going thru your pump if you didnt have one of these magnets.
I believe its a valid design. I'll prolly use on myself once i get my engine together, in conjunction with the magnetic drain plug. They both add another level of protection to your motor, without hindering flow rate in any form. If you got the cash for it, its prolly good insurance.
