am i the only one like pissing my pants in anticipation of those new cylinder heads that zzp is coming out with in february?? all aluminum and they're claiming 300 crank horseys on N/A cars!!! i believe them too cuz i know that if you engineer stuff right, you can get a ton of hp outta our cars.
cylinder heads!
Re: cylinder heads!
Aluminum is just a tad bit over rated, in my opinion. Why not just go with cast iron ones and port them. The only thing you are saving on is weight. ;)Last edited by Leonard 3.8L; 10-26-2007, 06:55 PM.
