cylinder heads! - FirebirdV6.com/CamaroV6.com Message Board
cylinder heads!
  • cylinder heads!
    am i the only one like pissing my pants in anticipation of those new cylinder heads that zzp is coming out with in february?? all aluminum and they're claiming 300 crank horseys on N/A cars!!! i believe them too cuz i know that if you engineer stuff right, you can get a ton of hp outta our cars.
    2000 3.8L Camaro A4 Pewter Y87<br />K&N Filter, SLP Ram Air kit, Eibach Pro Kit, Flowmaster 80 series, Silverstars, NGK plugs and MSD Super Conductor Wires, Electric Water Pump
    Re: cylinder heads!
    :rolleyes:
    (looks around slowly)
    It appears that you are alone in this one. But, aluminum cyl. heads do sound pretty cool, and I want some.
      Re: cylinder heads!
      just wait till you see the price tag, you will be singing a different tune.
        Re: cylinder heads!
        my thoughts, heads are freaking expensive, especially at low numbered leveles.
          Re: cylinder heads!
          as my teacher says,
          " Good head is always hard to find, and when you do... It's expensive "
          *Matt
            Re: cylinder heads!
            they will own, hopefully they are under 3 grand
            Camaro V6 - 14.3 @ 96mph
            Camaro SS - cam/boltons/m6/tune
            http://www.crfhq.com
              Re: cylinder heads!
              if you are short on cash it will be a better choice to go FI other than the heads, most likely. (assuming they are around the 3,500 range.)
                Re: cylinder heads!
                Aluminum is just a tad bit over rated, in my opinion. Why not just go with cast iron ones and port them. The only thing you are saving on is weight. ;)
                Leonard
                www.fquick.com/96V6Junkie
