The V6 beast lives again...... only better now - FirebirdV6.com/CamaroV6.com Message Board
  • The V6 beast lives again...... only better now
    http://www.fquick.com/garages/viewvehicle.php?id=125
    :naughty: :naughty: :naughty: :naughty:
    soon i shall hit the track
    www.turbov6camaro.com
    1997 3800 Series II Camaro
    Re: The V6 beast lives again...... only better now
    Keep up the good work man! :tup:
    1997 Camaro RS A4
    2006 Chevy Colorado
    2003 Kawasaki Ninja ZX6-R
      looks nice love the car there are few 93-97 models i really like and yours is one of them
        Is mine one of them? :p J/k.
        1997 Camaro RS A4
        2006 Chevy Colorado
          diggin' the yellow/black
          1999 Camaro Z/28
          1973 Firebird Formula
            How much is an Abbott engine?
              too much if u have to ask lol
              87 Firebird RIP
              96 Camaro RS RIP
              94 Patriot Red 1LE Z28 - Sold
              02 WS6 TA - Sold
                how dare you just give us a sound clip!!!!!!!
                I was all ready to start mine last night and just missing the plate that holds my throttle cables, well good work on everything......i was just thinking it would be badass to line up next to you some day
                : O
                  You guys should line up, we should try to get a big meet together, plan it like a year ahead of time so no one can b*tch about not being able to make it, btw viper your car is soundin good.
                    It would be bad *** to get a meet together with say like the top 10-20 time slip holders (unless my car blows up sky high i should be there) together for a meet.....now that would be BAD ***
                      and I would give you a ride home in my high 14's car if it did lol
                        you work too quickly......lol
                          Congrats to both of you (dan and andrew) on getting the engine back and in!
                          I just wanna hear what all the rebuild consisted of...
                          any New parts? any FREE mods to the engine itself?
                          thnx
                            glad its rollen again :D
                            2000 3.8 A4 Pewter Camaro
                              thnx
                              well lets see.....
                              lets start with the free mods, really the only free mods I have done is removing all the heat shields, a/c, some worthless bracketing, etc. All my free mods consisted of only weight reduction. Also !EGR
                              New parts...well the main new part was the addition of the L32 short block out of a 2005 grand prix GTP. This motor comes stock with lower compression (8.5:1) and forged connecting rods. In addition to that I got a performabuilt Level 2 Transmission coupled up with a fuddle racing 4000 stall.
                              well...theres a lot, heres a mod list the best i can think of...
                              L32 GTP Short Block 8.5:1 compression, forged connecting rods
                              Comp Cams Hardened push rods
                              Rollmaster double roller timing set
                              Msd blaster coils
                              Vavle cover Breather
                              Nology Hot Wires
                              NGK TR6s
                              Magnaflow 3” exhaust
                              3” elec cut out
                              High flow cat
                              65 lb Mototron injectors
                              Stattama Stage 4 turbo cam
                              Abbott Stage 3 heads
                              Abbott ported upper and lower intakes
                              130lb valve spring
                              Titanium retainers
                              Oversived SI valves
                              Cometic .065 MLS gaskets
                              Meziere electric water pump
                              80 PSI @ wot Oil pressure kit
                              Arp head studs
                              1.7 comp cams pro mag roller rockers
                              160 degree drilled thermo
                              COMP OER lifters
                              Innovative LC1 Wide Band & gauge
                              HPtuners
                              Racetronics Elec fuel pump Kit (with 225lph walbro)
                              SLP 85 MM MAF
                              Royal purple diff and tranny fluids
                              Mobile 1 full synthetic motor oil
                              Cobalt BOOST,FUEL PRESSURE, & A/F RATIO GAUGES
                              Vizage Body Kit
                              35th Anniv Stripes
                              Billet grille
                              Two tone brake calipers and shoes
                              Black Halo head lamps
                              HID conversion kit to 7,000K
                              Black Altezza tail lights
                              Clear front and rear corner lenses
                              5% tint
                              Edlebrock torque arm
                              UMI panhard bar
                              UMI LCA’s
                              Drilled and slotted brake rotors
                              Sub frame connectors
                              Sumitomo HHr4 tires
                              KYB 8 way adjustable struts
                              T/A Diff Cover
                              Weld pro star 15x8 rears with M/H slicks
                              Weld Pro Star Skinnies 3.5x15 with Moroso specials
                              SLP Line Lock
                              Snow Performance MAF Meth. Injection Kit (with Nitro Meth additive)
                              HKS SSQV BOV
                              Greddy Profec B-spec II boost controller
                              FFF Forward Sweeping Turbo Headers
                              Turbonetics T70 ceramic ball bearing turbo
                              Turbonetics 42mm racegate
                              Spearco intercooler
                              3.42’s LSD
                              B&M deep transmission pan
                              4000 Fuddle racing PRO SERIES stall
                              Weight reduction:
                              Heat Shields
                              Spare jack
                              AC
                              Back seat delete
                              Prostars (race day only)
                              ! Pass seat (race day)
                              ! Cat back (race day)
                              Motor Deletes
                              Water pump (electric)
                              EGR
                              AC
                              (im currently running the smallest 6 rib belt that autozone sells, lol) a total of 4 pullies
