tonight i was out in the shop trying to take my 18'' wheels off and put my stock ones back on.. cause all the bigger tires were going bad and splitting.. i got 2 of them off and switched and on one of the others one stud broke.. and another lug is stuck... and on the other one i cant even get the little lug cover thing to come off... any ideas on how to get these off?!
help!!
Re: help!!
i have to go to school in the morning... all my important classes are at the beginning of the day..1999 Black Pontiac Firebird <br />2 Rockford Fosgate P312D4 subs <br />Hifonics Brutus 1205d amp<br />Clear Sidemarkers<br />18\" Arelli Jovan Chrome Wheels
Re: help!!
i hate it when that happens...one time i got a flat on my old cutty. 3 broken studs and 1 stuck lugnut later I still had a flat
I lubed it up, let it soak for a while, and got a lugnut wrench and put a 4ft pole on it for leverage to get it off1999 Camaro Z/28
1973 Firebird Formula
Re: help!!
don't cross thread or over tighten your lug nuts again. you could try to break the lug nut off but that will definatly scratch your wheels.
Re: help!!
if you have to get somewhere in the morning, put the tires back on and drive carefully with the one lug broke. i fyou still have 4 of 5, you should be ok...
oh, and in teh future, anti seize is your friend.. itll help keep that from happening...Phill<br /><br />95 camaro... need money for turbo project... <br />94 S10 Blazer - winter beater - infinity system to be installed soon<br /><br />\"The man who says it cant be done should not interrupt the man doing it...\"
Re: help!!
Originally posted by camaroman1181if you have to get somewhere in the morning, put the tires back on and drive carefully with the one lug broke. i fyou still have 4 of 5, you should be ok...
oh, and in teh future, anti seize is your friend.. itll help keep that from happening...2000 3.8L Camaro A4 Pewter Y87<br />K&N Filter, SLP Ram Air kit, Eibach Pro Kit, Flowmaster 80 series, Silverstars, NGK plugs and MSD Super Conductor Wires, Electric Water Pump
Re: help!!
i ended up pryin the lug cover off finally.. then that wheel came off fine.. and i broke off another stud on the other tire.. but could still get a lug on it.. so we tightened it up and bought more studs today... it rides so much better on stock tires... its amazing.. haha1999 Black Pontiac Firebird <br />2 Rockford Fosgate P312D4 subs <br />Hifonics Brutus 1205d amp<br />Clear Sidemarkers<br />18\" Arelli Jovan Chrome Wheels
