real bored 0-60 in almost stock 3.4 - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: real bored 0-60 in almost stock 3.4
    Originally posted by Fbody3400
    Both of my f-bodies have/had 3.23s. I think its a real good gear, a perfect mix for performance and economy
    IMHO 3.42 is a perfect balance.
    3.23 FTL!! I would only get 3.23 if I did mostly ALL highway driving and alot of it!
    Or if I was racing the autobahn
    Sure 3.23 might lower your rpms = which is less gas
    but with 3.42s, it raises your rpms = closer to your power band (so you are making more power) which almost negates the "lower rpms = less gas/better MPG" arguement I just made! Do you understand?
    • #17
      I can give you a good example. A few years ago My wife wanted a Ford Sport Trac. I'm not a Ford man but she wanted a small truck and the towing capacity was best in the Sport Trac. So we look and drive the first on and I didn't like it. It seemed weak. I told my wife no. She said that this one had 3.73 gears but there was one at a differant lot with 4.10. We checked it out and ended up purchasing it. She then got on some Sport Trac group and found that she got better GPM that one with the 3.73 gearing.
      Luckly she changed her mind and this past summer I got her a real truck Z71
      2000 Firebird A4, 3.42 LSD, K&N, Free Cold Air, PaceSetter, 3" in/out Catco, 3" S-Pipe, 3" Intermidiate Pipe, 2.5" Flowmaster 80
      • #18
        Good story!
        well dude, If you are comparing different truck brands... that is kinda apples to oranges. Cause FORD might have a higher gearing in their TRANNY than Chevy (or vice versa). AND different models/years of trannys will probably have different gearing. So alllllll the gearing has to be taken into account: the rear end gears as well as the tranny gears.
        But I like how you helped prove my point that a numerically (#) higher gear will put the engine closer to where it makes GOOOOD POWER!! So therefore, it doesnt totally loose out on MPGs!!
        • #19
          Thanks, but the different gearing were both Sport Trac's with everything the same except the gears.
          I just mentaioned the Z-71 so everyone would know that after suffering 2 years with a small FORD truck, we now have a real truck.:banana:
          • #20
            Nice video ............. and yes , 3.42 FTW............. it's just perfect, peformance +gas mileage + comfortable highway cruising .......... :D
            09 Nissan 370Z MB M6 Sports Package
            www.the370z.com
            • #21
              my 95 auto goes 75 in second if i red line it didnt realize the manuals where that diff. my cuts out at 115 not 108 nice vid
              • #22
                i have 3.42's and an auto...def a really good ratio
                110mph in 3rd gear at like 5.3K or so (I was concentrating on the road)
                1999 Camaro Z/28
                1973 Firebird Formula
                • #23
                  I have an auto and am Back to the stock 3.42s (again!)
                  I really like the 3.42s for all around DDing / highway.
                  I HAD 4.10s till they grenaded (I miss them :( )
                  If I had a choice again... 3.73s auto
