I Have a 1995 V6 Camaro,with Flowmaster Cat-back exhaust,Magaflow high flow-cat, pace setter headers, jet stage two proformance chip,street underdirve pulley's, cold air intake, shift kit, 45,000 volt coil packs, MSD wires, heads shaved to 10,000's, 180 low temp thermostat with a new top end... just replaced head gaskets... valve job and such... with starting at 160 hp how much hp should i have now???
I need some info on my camaro
Re: I need some info on my camaro
1hp
instead spend 50 bucks and get a dyno run in. every car is different.
Originally posted by Josh95CamaroI Have a 1995 V6 Camaro,with Flowmaster Cat-back exhaust,Magaflow high flow-cat, pace setter headers, jet stage two proformance chip,street underdirve pulley's, cold air intake, shift kit, 45,000 volt coil packs, MSD wires, heads shaved to 10,000's, 180 low temp thermostat with a new top end... just replaced head gaskets... valve job and such... with starting at 160 hp how much hp should i have now???
