Just got done pulling the head - FirebirdV6.com/CamaroV6.com Message Board
  • #31
    Re: Just got done pulling the head
    that sums it up very well, pretty ****ty luck
    • #32
      Don't give up hope man. Hope is what keeps me going in life. Specifically- Hope that someday I will have my 2002 sunset metallic orange WS6 with TT2's. There is a reason why your motor broke down, perhaps it was just a fore-warning so you can bullet-proof your motor even more to prevent problems down the road. Good luck and dont lose hope!!!!!
      • #33
        heres just some other pics i took
        nothing to do with the problem, just having fun with the new camera
        • #34
          Is it easy to pull the heads? Just wondering..
          Camaro V6 - 14.3 @ 96mph
          Camaro SS - cam/boltons/m6/tune
          http://www.crfhq.com
          • #35
            Sounds stupid but maybe the simplest things. Check torque values when buttoning it up again. Replace the head gasket, if it's had a lot of weight on and off of it, it may distreess a little bit. just my .02
            • #36
              Originally posted by speedyz
              So, your turbo'd motor (I've been following these forums for a long time, just been too lazy to make an account), after you got your spark, etc. figured out, it finally runs, and the FUBARS on you? Damn cars.....love them to death but hate them for the hassles.....strangely similar to women......oh well all will end up OK and your motor will eventually be running, and you will beat viper :)
              yeah yeah
              we both have to stop having ****ty luck first
              www.turbov6camaro.com
              1997 3800 Series II Camaro
              • #37
                did you check everything we talked about last night? your not on AIM so i gotta ask here.
                • #38
                  pulled it almost 8 times now, i can do it in under 2 hrs
                  Originally posted by viper04af
                  yeah yeah
                  lol at our luck changing
                  havent gone home yet today
                  im pretty thurough with torque values, and this is my second set of MLS gaskets, they are brand new, and no way i am dishing out another 150 for my third set.
                  • #39
                    is that supposed to look like that?, only other thing i can think of would be piston rings, but that would not explain the coolant
                    • #40
                      That's not actually the cylinder wall where' you're seeing that shape. I think it's the top of the block. Look at this pic he posted earlier, looking down into the cylinder:
                      Looks to be the outline from the gasket.
                      ~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
                      • #41
                        thats what I was pointing out earlier...
                        • #42
                          you are looking at the edge of the gasket which is larger than the cylinder
                          • #43
                            dropped the head off today, company does not magnaflux, but does do pressure testing, and will recheck all surfaces, hopefully i will have an update tomorrow.
                            • #44
                              if it's abbott's fault shouldnt they replace the head?
                              • #45
                                they either pressure test or flux all heads before they go out, so its not their fault
