c5 wheels question - FirebirdV6.com/CamaroV6.com Message Board
c5 wheels question
  • c5 wheels question
    Does any one know why stock corvette c5 wheels will not fit on a 1995 camaro… I went to get them on today and they said they wont fit due to the hub or something like that. I was mainly wondering if there was anything I could do to make them fit?
    Has any one else had this problem?
    Re: c5 wheels question
    you should be able to put a spacer on and then they should fit just like...How wide and 17s or 18s?
      the rears might be to wide unless i tub out the wheel wells.. the rears are 18x10.5 and the fronts fit fine...
      do you know what kind of spacers i could get?
        You need to slightly grind down the rear hubs...real easy and they should go right on
        1999 Camaro Z/28
        1973 Firebird Formula
          do you think the 10.5 inche wide will pose a problem?
            My 9.5's come close but no rubbing at all...
            You might have issues, you can get spacers then.
            1999 Camaro Z/28
              width of 10.5 in the back will be no problem. yeah, this has been discussed many times. the hub needs to be ground down a little
              2000 3.8 A4 Pewter Camaro
                yeh would be fine my bros running 10.5 Z06s on this 00 and there fine. But the spacer makes them stick out more and looks bad @$$ in my opiton..
                  cool thanks all... really appreciate the help
