What gas do you use? - FirebirdV6.com/CamaroV6.com Message Board
  • #61
    Re: What gas do you use?
    7% or higher huh? well seeing as how normal is 12-18% for our engine and anything over 30% requires service, kinda goofy.
    rings have the gap for a reason. they need to be able to expand and contract.
    2000 3.8 A4 Pewter Camaro
    • #62
      i would imagine that the overlapping rings would expand and contract also. but i don't know. i figure instead of having a certain amount of space between each ends - - like so... im sure it just -_ overlaps. so one part would slide under the other part of the ring... correct? really i have no idea, haven't messed with rings yet. oh well, im sure somebody knows the answer=\...
      • #63
        normal rings are like this - -
        • #64
          they look like this....
          Thats how they over lap. Now those vs. new standard ones compession ratio I dont know. I was told by a ASE master tech who has takin all the ASE tests for ever feild that it raises it. Noticeably??? I doubt it. Now it wouldnt be from 9:1 to 10:1.
          • #65
            The total seal rings look like that or conventional? cause conventional doesn't look like that
            • #66
              Neither...What brand mine are I dont know. They were givin to me by a freind who didnt need them (decided to go with an 8). But that is what the ends of mine look like.
              I know what standard rings look like I've bulit more then 1 engine.
              • #67
                they do make all sorts of styles :\
                • #68
                  I always put 87 but for some reason i filled up with 93 today. I don't know why
                  09 Nissan 370Z MB M6 Sports Package
                  www.the370z.com
                  • #69
                    It said NEWLY conventional installed rings have leak down figures of 7% or more. So...maybe its correct. 7% (and worse) compared to straight 2% (unchanging) sounds awesome
                    but yer right, sounds too good to be true
                    • #70
                      correct, the pressure is still able to get behind the (mostly compression) ring in-order to expand the ring and seal the pressure inside the bore
