eh Supra - FirebirdV6.com/CamaroV6.com Message Board
eh Supra
  • eh Supra
    Found a possible replacement for my camaro :cry:
    And noticed it has 4.10 gears to a manual trans...I thought this was pretty high considering the gears in our cars.
    Do toyota gears work the same as GM? or does GM just put small gears in cars. I thought 4.10's were really high for a stock gear ratio...
    1999 Camaro Z/28
    1973 Firebird Formula
    Re: eh Supra
    Most four bangers will have gear ratios over 4.00...
    Originally posted by SSMOWS6
    i mean, you can always fly wes out there and since he's a tool sometimes, fashion him into a plow for the maro
    R.I.P. '07 Pats
    Still... 18-1 > 1 and done
      Re: eh Supra
      Supra is an inline six. If it has 4.10's then it is either not a stock rear and/or gears. How much is it? How many miles? For a well equipped last generation supra you should be paying in the mid 20's to low 30's, if it's really cheap there's a problem.
      Let's flip a coin. Heads I get tail, Tails I get head.
        Re: eh Supra
        Not unless we're talking about a 89 with over 100k miles.
          Re: eh Supra
          This is true, in which case you would just be buying it to say I own a supra but would be too embarrased to show it to friends or family.
            Re: eh Supra
            TRUTH FTW
              Re: eh Supra
              The 88-89 Turbo'd Supra's came with somewhere in the lower to mid 200's for HP. Not sure if it is wheel/crank.
                Re: eh Supra
                It's a 83 stick, I6 (rated 150hp/160tq)
                It's $300 and it needs an Ignitor (I found a used one online for $50), I'm going tomorrow to look at it. 200K on body, 40K on drivetrain.
                They did come with 4.10s stock tho
                1999 Camaro Z/28
                  Re: eh Supra
                  didn't know that. Well If you have access to Gran Turismo according to them the car has serious potential, they can even make them look good. Personally I wouldn't but if you need a beater then that sounds good. Def underrated if you want to tune on it.
                    Re: eh Supra
                    I know that.
                    R.I.P. '07 Pats
                      Re: eh Supra
                      They kinda remind me of old porsche's, being a Supra and with all those damn tuners, I'm sure it would have a decent resale value once fixed up.
                      Anyways, I think it's the "best possible" replacement for the maro for under $500 and I just thought it was wierd that it had such a high stock ratio...
                      1999 Camaro Z/28
                        Re: eh Supra
                        Its not really that wierd.. if you've only got a little bit of power you need those short gear ratios to make it go fast.. thats what i was trying to say by bringing up the 4 bangers.
                        R.I.P. '07 Pats
                          Re: eh Supra
                          Not RWD generally, in FWD it's not uncommon to see some step up to a total final ratio of 4.6x's and there are some aftermarket kist that step up to almost 5.xx
                            Re: eh Supra
                            Why cant they put 4.10's in fbody's :(
                            1999 Camaro Z/28
                              Re: eh Supra
                              stock no, aftermarket yes. You can have anything you want, just spend the $$
