Supra Help Please - FirebirdV6.com/CamaroV6.com Message Board
Supra Help Please
  • Supra Help Please
    Hey, I made a post the other day about getting a Supra for $300. Anyways, I go to check it out today and it gets spark just fine. I can smell gas under the hood so it's getting past the pump and filter. However, it cranks over but does not fire.
    Does anyone know what this could tell me? Seems to be getting spark and gas...oil was free of coolant, although it looks like it had just been changed.
    (I joined a Supra forum but they are really slow with the replies and I need to know ASAP...and they talk in Toyota jibberish, idk wtf there talking about)
    1999 Camaro Z/28
    1973 Firebird Formula
    Re: Supra Help Please
    what year n motor?
    <a href=\"http://photobucket.com/albums/a371/boyoi/firebird/?sc=1\" target=\"_blank\">My FireBird</a> K&N intake,Gutted cat, glass pack muffler.........Lots more to come...... <br />Getting my exhaust soon :)Rumbler Exhaust w/ Hooker\'s Headers :)
      1983 2800gt 5m-geu Dohc
      It has a distributor and I BELIEVE it is EFI
      1999 Camaro Z/28
        if you have spark, you need to find out if fuel is getting into the combustion chamber. pull the plug if you can and see if fuel comes out... be careful and do not allow the spark around it.
        2000 3.8 A4 Pewter Camaro
          Ok, I will try that tomorrow
          A. If fuel comes out this means....
          B. If fuel does not come out this means...
          1999 Camaro Z/28
            A. it should go boom
            B. could have clogged injectors, injectors are not firing at all, clogged fuel filter, bad fuel pump.
            let me ask this, what kind of fuel system does it use? it doesn't have a carburetor does it? if so, I'm out
              Nope it's def. some sort of fuel injection
              I will hope fuel comes out, but then that would be puzzling if it's getting spark and fuel I'd have no idea what to do next...
              unless if the timing is really bad?
              The guy said everyonce and awhile it will fire up?!?
              1999 Camaro Z/28
                could be i guess. concepts are the same but those engine designs are a lot different that what i work on and what i recieved my education on....let alone its over 20yrs old. I wasn't even born in 83
                  yep, very different
                  thanks for the help...I will try that tomorrow
                  1999 Camaro Z/28
                    if you have spark and fuel you have ignition.....
                    only way you dont is if you have no compression what so ever, even at that point you still should get something.
                    pulling the pluds and smelling/looking for fuel is effective as Blldogg said, I doubt these cars have fuel rails with pressure check points (schreder valves), but that would help too
                      Well I bought the car today.
                      I did a compression test and it tested fine...
                      However, I pulled the plug and cranked it and no fuel came out so it's not getting fuel after all...looks like I'll be tinkering with it for awhile.
                      1999 Camaro Z/28
                        Sweet an Inspector Gadget car!
                        This means you're selling your camaro tho doesn't it? :(
                        Originally posted by SSMOWS6
                        i mean, you can always fly wes out there and since he's a tool sometimes, fashion him into a plow for the maro
                        R.I.P. '07 Pats
                        Still... 18-1 > 1 and done
                          or I can make it a Delorean clone or something
                          I'm still not sure, but if the price is right, anything is for sale
                          I still have to get this heap running before I can do anything tho
                          1999 Camaro Z/28
                            i have to be honest, that is uggggggg leeeeeeeee
                            Follow me!
                            Or this
