Stupid Technician - FirebirdV6.com/CamaroV6.com Message Board
Stupid Technician
  • Stupid Technician
    Something happened yesterday at the Firestone I have to tell y'all about.
    I stopped by to get a couple new tires. When I returned to pick up my car the tech said, "We noticed your check gauges light was on. We went ahead and pulled the codes, but there weren't any. We messed with the car a little, but couldn't find anything right off the bat. Would you like us to do a deeper analysis? We would have to charge you though."
    I said, "No, I know what's wrong with it."
    "Oh, is there anything we can do to help you?"
    "Not unless you have a can of gas back there. The check gauges light is on because it's low on gas. You are thinking about the check engine light. That's what would through a code." :twak:
    So says the tech, "Oohhh..." (you have to say it like you just discovered the meaning of life)
    Maybe I just caught them on an off day... I hope.
    Lounge Moderator
    Re: Stupid Technician
    I would go ballastic if I went in for tires, and they started pulling codes.
    http://www.cardomain.com/memberpage/799659
      gee, whenever any of my cars get low on gas, they throw a low fuel light. that's their code for me to get more fuel.
      2013 Ram 1500 Big Horn
      94 comero 3.4
        So let me get this straight..they see a "Check Gages" light and instead of checking the gages, they start ****ing around with the car's computer, all while they were only authorized to mount tires? We all know what bus those Firestone employees rode in on....
          Our check gages light comes on for low fuel? Huh.
          1998 White Camaro 3800, A4, MagnaFlow Cat-Back, Zexel & 3.42's, Jet Chip Stage 2, Whisper Lid, and Ram Air.
            No way that any of them could have ASE cert's!!
            2001 Black Z28 M6<br />Sprayed, slotted, geared and more~
              you dont need one to work there haha
              but you know it's bad for your fuel pump if you go low on fuel all the time
                Yeah... I have the hand written check sheet from the shop on my desk. It reads, "check gauge light on, courtesy scan - no codes"
                Lounge Moderator
                  thats why you don't go to Firestone.
                  the Firestone across form my dads shop is pretty shady i don't think many of them are ASE certified.:omg:
                  -Y87
                  Lid,K&N Filter,PaceSetter Headers,Magnaflow Cat 2.5in S-pipe,Flomaster :(,3.42 LSD
                    pep boys tried to ruin my wheel studs...i about broke my back trying to take the rear wheels off cuz they freakin tightend the lugs to tight...im wondering if they were certified...
                      ^ Yep. Seems they all do that: overtighten the lugs. How the hell do you change a flat if need be? :slap:
                      2004 CE Corvette 10.86@132mph
                      2011 Cadillac CTS-V
                      2006 Mitsubishi Eclipse GS
                        thats exactly what my dad said after he bout broke his back trying to take them off too...we had to take a freakin socket wrench 2 get the lugs off...not even our air wrenches would get them off :mad:
                          Personally I have always had better luck going with small local auto shops that have been around for a long time. Usually a longer wait, but the price is cheaper and usually it doesn't take long to find one you trust.
                            that's why I try to always watch them put the tires back on and ensure they use a torqe wrench. Asked one guy if he was going to use one and he looked at me like I was stupid. I responded, yes you must use a torque wrench set to 100ft/lbs. He had no clue what I was talking about. This was of course after he started trying to torque them down in a circle pattern with just the impact.
                            Last time I wasn't there when they put the wheels back on so when i got the car home I pulled out my torque wrench and re-tightened them.
                            -Brad
                            2000 V-Star Custom 1100
                            :rock:
                              not only does it possibly bend your wheels, it warps your rotors as well
                              2000 3.8 A4 Pewter Camaro
