ok i searched this forum for the seafoam write -up couldnt find it n also searched stangnet n corrall..can some1 show me a picture or what my brake booster line looks like? i just dont wanna mess it up
i have a 1995 gt...any help is appreciated
edit- is it a thick hose like right infront of the steering wheel connected to that big drum thing?
Originally posted by fordmn1966
that's most likely it! it goes into the upper intake manifold! when i took my brake booster line off the car died so i just used the PCV line going to the valve cover. just pull it off the valve cover and suck up the seafoam with it. :thumbup:
Originally posted by wazzup242
Yes that big black drum thing is the booster, it should be a pretty thick line, maybe about 3/4" Make sure u take it off of the check valve and do not poor fluid into the check valve or booster, yours might have a small hose clamp on it but pull that off and poor it into that line towards the engine
That is on a newer sixer but it should be pretty close to yours
normally...id kno exactly what the brake booster looked like. ive seafoamed over 20 cars (friends and family) but this 96 GT apparently didnt have power brakes or something so the previous owner did something else. there isno big black drum. weird huh? i guess ill just use the PCV valve
3 days ago
