Question About Deleting Files... - FirebirdV6.com/CamaroV6.com Message Board
  • Question About Deleting Files...
    Alright here's the deal, I have a folder with about 7,000 files, and another folder with 1,300 files. Every file in the the smaller folder is a duplicate of a file from the bigger folder. It's a temporary folder. I need to now delete the original files from the master folder, and in the past i've always done it one at a time, matching the name of a file from the temp folder to the master folder and deleting it..
    Is there a faster way of doing this? Telling windows to delete files in a given folder with the same name as the files in another given folder?
    I doubt it but it's worth a shot, right?
    1996 Chevrolet Camaro
    1995 Buick Park Avenue Ultra
    --Appearance Moderator--
    Re: Question About Deleting Files...
    Delete everything.
    1995 Pontiac Firebird
      Open both folders, 1300-folder and 7000-folder. Highlight every file in the 7000 and drag them over to the 1300-folder. When windows asks if you want to replace the duplicate file with the new one, click no. All the duplicate files will be left in the 7000-folder, then just highlight and delete all of those
        But then wouldn't I be left with the same problem getting the remaining 5700 files back into the main folder?
          ^just copy those from the original 1300 folder back into the original 7000 folder
            right, but wouldn't I have to deselect the 1300 files to move the 5700 back? and in essence be in the exact same situation but opposite folders?
              oh. I thought you were just trying to get rid of multiple copies of the same files. Looks like you're in for a long night, going one by one and finding the duplicates
                Ok, try this:
                Open up your "Temp Folder"
                Hit Ctrl-A to select all files.
                Then Crtl-C to copy them.
                After that, open up your "Master Folder"
                Hit Ctrl-V to paste all the copied files from the Temp Folder. This will replace all of the duplicate files in the "Master Folder" with the ones from the "Temp Folder"; without deleting them from the "Temp Folder" location. Without hitting any other keys, every file you pasted should now be highlighted in the "Master Folder".
                Hit delete
                Click yes. This will delete all of the selected files, which happen to be the duplicates that are still saved in the "Temp Folder".
                Hopefully I got all that right. Give it a practice try on a couple files and see how it works out.
                ~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
                  thank you! that's what I was looking for. This seriously saved me about 10-12 hours..
                    Awesome dude. Glad it worked out for you.
                      Damn dude, you must have alot of porn..... :p
                      05' CTS-V
                      00' Camaro - SOLD :(
                        haha my thoughts exactly
                        1999 v6 Camaro M5
                        Automatic to Manual converted
                        Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
                        !cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
                          :eek:.. :naughty:.. :rock:
                          Nah, it's for work. Very important files, which is why i copied to a temp in the first place instead of just cutting and pasting each file to the new location.. just in case something goes wrong.
                            You have a job?
                              You prob need a good backup / file synchronization program - try syncback, if you go into the advanced options you can prob specify the behavior well enough.
                              (google syncback for the program home page)
                              2001 Pewter Firebird Y87, M5
                              Go Sabres!
                                My Hptuners stop working
                                Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...
                                13 hours ago
                              • Money pit
                                Zzp cams
                                by Money pit
                                Has anyone used zzp gt1 cam if so is it worth the money and time
                                2 days ago
                              • thatpewterfirebird
                                2001 3800 s2 firebird
                                by thatpewterfirebird
                                4 days ago
                              • Turbo 3800 camaro
                                Where are the videos?
                                by Turbo 3800 camaro
                                6 days ago
                                New Chevele
                                Just saw it on Facebook, looks awesome. The front and rear nice looking....
