suggestions for summer project - FirebirdV6.com/CamaroV6.com Message Board
  • suggestions for summer project
    after the success of my first major project (transmission swap,) im thinking about starting another one this summer. i will probably be starting a tech college for mechanics so that will only help. i want it to be performance relating to the engine. budget will probably be around $1000-2000. i want it to be a fairly big project.
    ive been throwing the idea around of the gtp supercharged 3800s, but searching here it sounds like thats pretty much out.
    open to any suggestions!
    1999 v6 Camaro M5
    Automatic to Manual converted
    Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
    !cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
    Re: suggestions for summer project
    wtf i know someone has a suggestion
    1999 v6 Camaro M5
      Supercharge your car.
      2001 Firebird 3.8L
        ^^ what part of South Jersey do you live? I am in SJ too
        09 Nissan 370Z MB M6 Sports Package
        www.the370z.com
          heads/cam swap!
            I'm in Glassboro, in Gloucester county.
            2001 Firebird 3.8L
              Used set of heads, manifolds and cam. That should make it grunt a little better.
                pretty close...i went there to pick up my Calculus book....
                www.the370z.com
                  Headers then Cam/Heads or Supercharger?
                  -Y87
                  Lid,K&N Filter,PaceSetter Headers,Magnaflow Cat 2.5in S-pipe,Flomaster :(,3.42 LSD
                    If you wanna spend a little bit more....
                    Stroke it!
                      supercharging/stroking would be too much money. plus i dont wanna make too much power because i dont feel like breaking my tranny or getting a gforce. if i did heads, that includes valves, rockers, etc right?
                      1999 v6 Camaro M5
                        P&P Heads/intakes(manifolds)/TB and get a cam.
                        That's what I think 3-4 of us are doing atm. Well the heads at least.
                          put a hybrid engine....:slap:
                          Horsepower is how fast you hit the Minivan... Torque is how far you take the Minivan with you... :wavey:
                          Originally posted by Firehawk N Wv
                          Mine were rusted also and the I had to cut my nuts off .
                            you would want new valves, new rockers arent necessary.
                            but if you do heads, you can run a thinner headgasket and mill the heads down a little. Up the compression. More compression = more power.
                            That is what im doing
                            going to be milling my heads .02 and using a .045 head gasket to up my compression to 10:1
                              if just got a mild cam, what else would need to be replaced?
                              1999 v6 Camaro M5
