Retarted clutch... - FirebirdV6.com/CamaroV6.com Message Board
Retarted clutch...
  • #16
    Re: Retarted clutch...
    700 seems a little expensive to me if all they are doing is replacing the clutch. Now if they are doing the flywheel, slave, and master it's a deal. If not you are getting ripped off.
    Figure a new stock clutch kit cost $200 and they comes with the clutch, pilot bearing, and throw out bearing. So they are charging you 500 bucks for r&r? that is crazy!
    fyi a new slave is around 70 bucks and a new master is around 100
    • #17
      i bought an OEM clutch and it was more than 200.
      the flywheel is pretty expensive.
      I think that's a pretty good deal, and he already stated above it's for all of it.
      *Matt
      • #18
        That is a bit expensive, but if you are not comfortable do not attempt it yourself. Make sure they resurface the flywheel, install a new throwout bearing, and make sure it comes with a warranty.
        I have done many rear wheel drive clutches, front wheel drive clutches, and a few heavy truck clutches. The easiest job ever took me a full day.
        For an amateur plan on a weekend just to be safe.
        The first one I ever did alone was a two day job. Day one was to pull it, clean it, and get the flywheel resurfaced. The second day was reassembly.
        • #19
          So, did you get it done yet???
          • #20
            Originally posted by black98V6 View Post
            I was quoted $300 for labor to change the clutch, slave cylinder, rear main and rear plate seal. I supply the parts. OEM clutch kits are relatively inexpensive and is fine for this guy if he is on a budget.
            Thats a good price on just labor
            I've had my clutch replaced 2 times both with nothing special and it cost over 800 for one at a "shop" and the other I had AMMCO do and it was 1100 or so. Right now my clutch is leaking fluid somewhere but I dont feel like spending that much money on swapping my clutch out until I get more miles on it. It's cheaper to just add brake fluid :cool:
            Originally posted by kala
            I'll have buttsecks with Richard Simmons!
            TEAM BLACK!!!
            parting her out
            • #21
              you need to make friends with somebody who has a roll back.....
              BAM redneck car lift....we put a 84 camaro up like that only front end 1st and stripped the entire drive train in under an hour
              • #22
                Its in the final process...Its an entire new clutch assembily, because only 1 throw-out bearing combined with a couple other problems ruined the entire assembily. It was a twin plated clutch, too...so I replace a twin plate with a twin plate. I should get it back on Wednesday.
                I ate a bowl of fail this morning.
                Quarter Million Mile Club
                • #23
                  Originally posted by StrtRacer98 View Post
                  hahahaha NO WAY can you pull a tranny, install a clutch and replace in 1 hour.
                  I pulled the tranny in my camaro quite a few times.
                  It takes 1/2 hr just to get to damn bell housing bolts out, maybe 1 hr.
                  Plus all the other stuff you have to disconnect, lining it up right etc. etc.
                  If your sort of have a mechanical background, and think you could do it... MAYBE?
                  But if you dont, I would highly suggest not doing it. Pain in the @ss.
                  I had so many problems come across when doing it, it wasnt fun.
                  In our case it took us an hour to get the drive shaft off.
                  1995 Patriot Red T-Topped Z28 A4<br /><br />Mystery rebuild in progress.<br /><br />Soon to have 383 ways to beat KBreezy and Shane. :D
                  • #24
                    *sob* I want my 'maro back...she begs to be driven around the lake a few times...
                    • #25
                      I love driving an auto. F your clutch probs.
                      1995 Pontiac Firebird
                      • #26
                        Fuc* yo couch!!! wait no, Fuc* yo clutch!!!
                        09 Nissan 370Z MB M6 Sports Package
                        www.the370z.com
                        • #27
                          lmfao! My leather couch is looking a bit worn though...I do want to attack some corners, but I dont think a Ford F-150 or a Dodge Stratus can handle my kind of driving.
                          • #28
                            No joke. I've been driving my dad's 89 Chevy pickup with a carbureted 305 SB from a Monte SS. It sucks. I miss the Camaro. I did see it sitting over in front of some rinky dink barbershop last week. At least he hasn't wrapped it around a tree.
                            Originally posted by LETZRIDE
                            I've never touched a rear end before
                            • #29
                              Two days feels like a month...oh wait...it has almost been a month since I've last drove the car like it should...
                              • #30
                                Tomorrow! Woohoo!!!! New Stage 2 Clutch!
