So how do you guys use it?
Traction Control
Re: Traction Control
I've got full blown stability control...it stays on all the time, to much of a hassle to turn it off, keeps me from blowing through tires as well...and of course the obvious safety factor...if it can help me I'll use it....it's only a few seconds to turn it off and play anyways....
05' CTS-V
00' Camaro - SOLD :(
I thought only Z28s had traction controls??? I could be wrong. 3800 autos have 2nd gear start. In slippery weather (i.e. heavy rain, sleet, snow etc) the transmission will start the car in 2nd gear instead of 1st. Just an annoying useless feature . You're suggested to avoid using it since it causes problems to your trans.
BTW, where is the option to select, "GM should've used the money toward flattening out the passenger side floor bump rather than the stupid 2nd gear button" ?
:)Last edited by kala; 03-18-2008, 03:34 PM.
Originally posted by kala View PostI thought only Z28s had traction controls??? I could be wrong. 3800 autos have 2nd gear start. In slippery weather (i.e. heavy rain, sleet, snow etc) the transmission will start the car in 2nd gear instead of 1st. Just an annoying useless feature . You're suggested to avoid using it since it causes problems to your trans.
+1 would have ben better spent money
i cant believe how many of you dont know whats under the bump.
i dont have it, so duh i dont use it.
Follow me!
Or this
