Top speeds in 3.8 Fbodies
This topic is closed.
Re: Top speeds in 3.8 Fbodies
Originally posted by TheGr8Schlotzky View PostI do, however, find it hard to believe that a completely stock F-body with the exception of !limiter, would be able to reach the same speed as a car with the same gearing and 3 times the power on any length of road.
So an F-body could infact reach a higher top speed than another vehicle with more power and the same gearing.. but only if its frontal surface area was significantly less (like if it was racing a box truck or something ;) )
Intrestingly the first stock bodied car to break 300 mph was an F-Body. Yep, a 3rd gen Firebird to be precise. Needless to say it doesn't have the stock gearing. http://www.kugelkomponents.com/bonne...onneville.html
Originally posted by SSMOWS6i mean, you can always fly wes out there and since he's a tool sometimes, fashion him into a plow for the maro
Still... 18-1 > 1 and done
Originally posted by Smoke Panther View Postthe mathmatical limits are as follows:
for a M5, 6000 rpm in top gear would put them at 197 MPH
for a A4, 6000 rpm in top gear would put the car at 212 MPH
Originally posted by Fireball27 View PostIntrestingly the first stock bodied car to break 300 mph was an F-Body. Yep, a 3rd gen Firebird to be precise. Needless to say it doesn't have the stock gearing. http://www.kugelkomponents.com/bonne...onneville.html
"We also run the stock rear spoiler from a 1990 Pontiac Firebird on our 1992 car because we feel that is the best spoiler that Pontiac has. It’s not an aftermarket spoiler, it’s an actual stock rear spoiler and it’s the one that starts on the glass itself and goes all the way around the deck lid."
"If you’re going to go 300 mph in a stock-bodied production car at Bonneville, the car of choice is a Pontiac Firebird," said Joe Kugel. "Out of all the production cars, it probably has the lowest drag as far as aerodynamics are concerned, and at 300 mph, this Firebird has to be the most stable vehicle that’s ever been built."
:drool:
Yes it may be true but the 3.8 does not have enough power to get it going that fast. You would however be able to do that if you had the power.
Even an LS would take a long time for it to get to those speeds.
Originally posted by sac2165 View PostThese cars were not meant to go this fast. After driving my C6 (really fast), driving the Camaro 100+ feels like driving a double-decker bus. That can't be safe.
Originally posted by F-Body_SS-Man View PostYes it may be true but the 3.8 does not have enough power to get it going that fast. You would however be able to do that if you had the power.
Originally posted by Smoke Panther View PostHow fast can a stock V6 f-body can actually get in real life? I don't know. But, what I do know is that, in each case, it will never go above the aforementioned speeds.
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...7 hours ago
