so i went to get my camaro out of the storage barn so i could drive it home! yay! so i do what i do every year hook it up to a battery charger for like 10 min and its cool right WRONG! i hooked it up and all my dash light are bight like normal but it didn't crank over it just clicked and clicked errr this pissed me off!! i just wanna drive it home (its parked in a town about 15 min away) I'm gonna go mess with it today maybe but IDK i would guess it might need a battery i bought it in 02 and never had a issue with it and i cant read the date on the battery of when it was installed or the CCA is it 650?
errrr! Battery ?
Re: errrr! Battery ?
I had a battery for only 6 months, sat 4 of those, came back, charged it, never worked.Y87 Package
MANUAL CONVERTED, Pro 5.0 Shifter
Pacesetters, Magnaflow Cat, Cutout, Flowmaster
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
Team Black...TEAM EMO
Come on kids! Get a Calendar!
Jump it...
But my guess you need a new battery, if you got the car in 2k2, and its on the same battery its likely dead.
Running batteries flat dead reduces sometimes kills the battery on the spot. Then add that its 6 years old and I don't think I have even heard of a battery lasting 6 years(but I live in FL, heat kills em) that you might need a new batt.
ok up date i got it home for some reason the positive side terminal was kinda loose so i tightened it up charged it for like 10-20 min and it started up just fine! but i parked it in my drive way and it dided again we have a little asz trickle down charger and i hooked it up last night so it should be good soooo WHAT IS THE CCA FOR OUR CARS IT'S A 95 3.4
Originally posted by kristen View Postdid you drive it after you started it? cause if you charge it for even 20 mins that might be enough to turn it over once. you need to get your car to start, THAN DRIVE IT. you battery wont charge to what it should be at until it's driven for a while.
and yeah, walmart batteries are $32, but other batteries are like 150...2002 SOM Camaro- Sold
2006 S60- Sold
2000 Cherokee- The desert whip
Originally posted by solocamaro95 View Postok up date i got it home for some reason the positive side terminal was kinda loose so i tightened it up charged it for like 10-20 min and it started up just fine! but i parked it in my drive way and it dided again we have a little asz trickle down charger and i hooked it up last night so it should be good soooo WHAT IS THE CCA FOR OUR CARS IT'S A 95 3.4
PS, I have NEVER seen a car battery more than $90 tops, and thats an Optima. Steve, if you're paying $150 for a battery, you're getting anal raped.1995 Pontiac Firebird
google "optima red top" all between 150 and 170.
here, 150 from advance.
http://www.partsamerica.com:80/Produ...Number=75359252002 SOM Camaro- Sold
2006 S60- Sold
