Fitness Questions - FirebirdV6.com/CamaroV6.com Message Board
Fitness Questions
  • Fitness Questions
    alrighty. Ive read around here. and ive seen we have someone, forgot the name but he knows a little about fitness.
    well i use to play football at the highschool, we would lift weights everyday and run and do other activities every other.
    Well i quite the football team weighing around 175 muscle, in shape and toned.
    Well over the last year and a half ive gotten up to 195, still a little bit toned, but losing muscle and getting chubby. I think.
    I need a workout routine or something to stick to to keep in shape and tone back up.
    I got a weightbench with enough weights and dumbbells, just need to know a routine and what else should i do to tone my stomach back down.
    Thanks for the help.
    Mods:
    Slp Dual Cold Air Intake
    Racing Stripes
    Flowmaster Exhaust [2.5 Pipes, Flowmaster 80 Series Muffler]
    Camaro Fill Ins
    Black Outs
    Tint
    Re: Fitness Questions
    that would be the mighty thor
    my other truck has a 50 cal mounted on it
      yeah talk to mighty. you could always do sit ups and crunchs for your stomach. then just start to run and or skate. both are giving you a twisting effect that works your trunk out.
      WAWA-A-HOLIC
        I would say running is one of your best options. Once your done with your run do sit ups. Run like 4-5 times a week. But talk to mighty thor, cause I'm really no expert on this.
        -Travis-<br /><br />1999 Hugger Orange Camaro-stock<br /> <a href=\"http://www.cardomain.com/ride/763509\" target=\"_blank\">http://www.cardomain.com/ride/763509</a>
          MT should start an online fitness consulting business!
          http://www.cardomain.com/memberpage/799659
            I shot up to 180ish when my reg. weight is 150ish. I got into biking and I'm back to 160 within 2 months. It's a lot easier for me than running, however, it can be much more expensive. Def. just get started on your cardio until thor shows up in here ; )
              I eat fast food all the time, twice a day actually, probably for the last two months, and I haven't gained a pound. I suggest McDonalds followed by a regiment of Baconators.
              Smoking a pack of cigs a day also helps. Inbetween smokes, I also suggest a tin of Skoal Mint long cut. When you get home, polish it all off with three cold Budweisers.
              1995 Pontiac Firebird
                i can just feel the health coming back to me...:rolleyes:
                  wellll heres something that might help...try it. ull see results...i promise
                  ok monday
                  Bench, inclide dumbells, flat flies, machine bench.
                  machine row, lat pulldown, calbe row, t-bar or bent rows
                  olympic bar shrugs
                  abs
                  wed
                  alternate dumbell, standing bar curl, preacher curl
                  tricep extension (behind head one), skull crushers, cable pull down
                  military press, upright rows, bent side laterals
                  abs
                  friday
                  front squats. leg press, leg extension
                  romanian deadlift, leg curl, seated leg curl, good mornings
                  calf raises, calf press,
                  abs
                  cutting up requires higher reps soooooo ur going to be doing 15 reps per set now...
                    I guess we can't hope for blood coming back to your brain can we?
                    • Manimal
                      Coil springs
                      by Manimal
                      4 days ago
                    • Manimal
                      Newby here
                      by Manimal
