v6 torque - FirebirdV6.com/CamaroV6.com Message Board
v6 torque
  • v6 torque
    Just curious...Is it even possible for a v6 camaro/firebird to lift the front end off the floor? like even an inch?
    How much torque and power would you need to make the car do that?
    Aside from slicks, I always wondered what it took for a car like ours to do that...
    Re: v6 torque
    I've seen pictures of james' car where a tire was off the ground an inch or so. Viper is likely doing the same as well as some others.
    1996 Chevrolet Camaro
    1995 Buick Park Avenue Ultra
    --Appearance Moderator--
      Re: v6 torque
      oh for sure they can
      WAWA-A-HOLIC
        Re: v6 torque
        what is needed to make that happen...like what kind of torque are we generating here?...I dont know james' car, but I know viper is running 11.2x right now so hes running some nice power right now...
          Re: v6 torque
          its not really as much about the power as it is the take off
          lets say you have 300 RWTQ, if you are just using your footbrake and brake torquing your car, you arent going to pull the wheels up, but if you have a trans brake, you are more likely to pull the wheels up
          especially with sticky tires
          and yes i know i didnt help you at all, sorry
            Re: v6 torque
            james is 12secondv6....car is no longer around. but i don't know his numbers. i'm putting out 336rwhp, and 412 rwt i don't pull nothing lol:rolleyes:
            WAWA-A-HOLIC
              Re: v6 torque
              if you run sticky tires with a good clutch setup im sure you could
              but be glad you dont, pulling the front tires off of the ground just shows your car isnt setup properly, and you are losing a ton of time
                Re: v6 torque
                oh im sure that i can....lol
                BUT IT LOOKS KOOL
                WAWA-A-HOLIC
                  Re: v6 torque
                  no I am sure with her power a good clutch and a sticky tire she would kill her tranny...
                  now if she had a good tranny, clutch, tires, suspension, and lost a little weight(the car, not you kristen) she could.
                  Its more about weight transfer/shock of power. I could get the front wheels to lift on my 92 GMC jimmy with a 4.3L v6... I had to get the truck rocking a bit first then the front would start lifting.
                    Re: v6 torque
                    i am the ultimate weight redution driver lol.....driver =93 lbs hehehe
                    WAWA-A-HOLIC
                      Re: v6 torque
                      There could be 3 of you in your car, and you would still have a driver weight advantage over me.
                        Re: v6 torque
                        even w/decent numbers, you still need your suspension set up right for weight transfer.
                        2013 Ram 1500 Big Horn
                        94 comero 3.4
                          Re: v6 torque
                          I never knew your car was that powerful. :tup:
                          2001 Firebird 3.8L
                            Re: v6 torque
                            haha, your like a jockey, maybe you should look at changing careers kristen, I heard they make a ton of money....
                            anyways yea thanks guy, I know its not good to pull up the front tires, infact I think it actaully isnt structurally good for the car when you come back down either, but it looks sweet....I always kinda figured it had to do with launching and the weight transfer, along with power of course...
                              Re: v6 torque
                              ^pretty much it...power has reletively little to do with it
