Re: Chevelle start
The 8.5 10 bolt can be built to hold 500hp no problem. If you have the 8.2 however, the first time that car hooks, its toast. A stock 9 inch is a little stronger than a 12bolt, but its also heavier and uses more hp to turn. Unless you swap gears often, get a 12 bolt. Either rear will do, but with 500hp, a 12 bolt will be fine. I put a moser 12 bolt in my 69 camaro behind a 425hp small block and I have no worries at all. I personally don't trust ebay for anything, but check around for deals on trannys. My bother put a Art Carr 200R4 in his 72 Nova. That tranny is rated for 750hp and the overdrive is nice on the highway.
