Tire Questions - FirebirdV6.com/CamaroV6.com Message Board
Tire Questions
  • Tire Questions
    I'm sorry if this is in the wrong section, but I have to get new tires for my rims. I was looking around ebay and found a set of 2 Nankang NS-II 215-40-R18 and a set of Nankang 205-50-R17. I was wondering if these would work together and if anyone knows anything about these type of tires. Never had to buy tires before so Im not sure what im looking for. Any help would be appriciated
    Re: Tire Questions
    those are skinny no?
      Re: Tire Questions
      Those are pretty skinny. I'd go with some name brand tires too; I've never heard of Nankang. Last I checked, tirerack.com had Summitomo HRT Z's for about $65 each. They'll last a long time, look good, and supposedly have decent wet and dry grip.
      ~97 3.8L V6 Camaro~
      A few things
      Only Member of Team Hooker?!?
        Re: Tire Questions
        So what size would you recommend?
          Re: Tire Questions
          if you have a 17-18" rim.....275's so long as the rim can fit it
            Re: Tire Questions
            what wheels are on your car? im pretty sure the stock tire size is a 215/60/16
            215= tire width
            60= side wall thickness
            16= tire size in relation to rim size
              Re: Tire Questions
              I have stock rims now but im putting on 17" and 18" c5's so i need tires that fit them
                Re: Tire Questions
                whats the width of the rim? i dont think a 215 width tire would fit those
                  Re: Tire Questions
                  if they are C5 rims 275's should fit on there...not sure what the sidewall thickness is on that size though....probably 35 though....
                    Re: Tire Questions
                    18"x 9.5" and 17"x8.5 are the widths of the rims
                      Re: Tire Questions
                      245/45/17 and 275/35/18 will do the trick.
                      1996 Chevrolet Camaro
                      1995 Buick Park Avenue Ultra
                      --Appearance Moderator--
