so i found a 93 camaro for 1800 it has 135k 6 speed. has new clutch. needs new battery , rear rotor and he says it leaking coolent at the back of the motor? what would be back there to leak? also when i started it up the check gage light is on and when u look at the gages the oil gage says no oil pressure. he says it's done that since he bought the car. do u think the car is worth it?
tell me what u think
This topic is closed.
Re: tell me what u think
Originally posted by 95firebird3.4 View Postso i found a 93 camaro for 1800 it has 135k 6 speed. has new clutch. needs new battery , rear rotor and he says it leaking coolent at the back of the motor? what would be back there to leak? also when i started it up the check gage light is on and when u look at the gages the oil gage says no oil pressure. he says it's done that since he bought the car. do u think the car is worth it?
battery: $60
Rotor: $45
Oil pressure sender: $35 (assuming that's the issue; could be something alot bigger, worst and more expensive!)
Gaskets + time + trial and error to fix the coolant leak: Not worth it IMO. You'll most likely just about completely rebuild the motor; if coolant's got into the oil, then it's screwed.
That and 93-95 are the dogs of the LT1; they're still faster then our 6's stock, but they're a PITA and slower then the later models.Last edited by RadRacer; 11-24-2008, 11:10 PM.~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
dogs of the LT1? ur a idiot. they arnt any worse to work on or slower than the 96/97 LT1s. 93s yes cuz they r chip cars. but seriously no its not worth it. U have no idea y its leakin coolant out the rear of the motor. Better get a opti to on that list of parts to get. Along with a WP. Wires and plugs too. Better hope that its just a sensor thats messed up and not the oil pick up broke or bent inside the pan. Theres to many "what ifs" with that car that arnt worth the headachsLast edited by SilverRS96; 11-25-2008, 12:36 AM.
87 Firebird RIP
96 Camaro RS RIP
94 Patriot Red 1LE Z28 - Sold
02 WS6 TA - Sold
Originally posted by SilverRS96 View Postdogs of the LT1? ur a idiot. they arnt any worse to work on or slower than the 96/97 LT1s. 93s yes cuz they r chip cars. but seriously no its not worth it. U have no idea y its leakin coolant out the rear of the motor. Better get a opti to on that list of parts to get. Along with a WP. Wires and plugs too. Better hope that its just a sensor thats messed up and not the oil pick up broke or bent inside the pan. Theres to many "what ifs" with that car that arnt worth the headachs
Originally posted by SilverRS96 View Postthe sensor is at the back of engine IIRC....take it out...thread a fittin with a line comin out of it to ur sensor
Follow me!
Or this
Follow me!
Or this
Follow me!
Or this
