ls1 vs 3800 - FirebirdV6.com/CamaroV6.com Message Board
ls1 vs 3800
This topic is closed.
  • Re: ls1 vs 3800
    Originally posted by bigbrian442 View Post
    Incorrect. The engine is in closed loop as soon as the heated O2 sensor is up to temp. That takes less than 60 seconds. It's a requirement of OBD II.
    oh really?
    might want to check this out...
    http://www.obd-codes.com/p0125
    • Re: ls1 vs 3800
      Originally posted by Firebirdkid96 View Post
      You really need to just shut up at this point. For your own integrity.
      considering another gm car i have gets a CEL about the coolant temperature not being warm quick enough, and looking it up numerous times, im pretty safe to say that i dont need to shut up, because it is NOT just the 02 sensors.
      • Re: ls1 vs 3800
        I suggest you buy a real scanner and watch when the PCM goes into closed loop. If the engine doesn't warm up in the allowed amount of time it will set that code. That description doesn't say the ECT has anything to do with the PCM entering closed loop.
        • Re: ls1 vs 3800
          well, im sorry that every code website interperates the code wrong
          "This means that the engine coolant temperature (ECT) sensor indicates that the engine has not reached the required temperature level to enter closed-loop operation within a specified amount of time after starting the engine."
          • Re: ls1 vs 3800
            Gee, and all this time i thought it was referred to as a SES Light or a MIL.
            Y87 Package
            MANUAL CONVERTED, Pro 5.0 Shifter
            Pacesetters, Magnaflow Cat, Cutout, Flowmaster
            MOGOB APPROVED!
            BONE APPROVED!
            VANBIBBER APPROVED!
            KRISTEN APPROVED!
            Vice Prez.
            Team Black...TEAM EMO
            Come on kids! Get a Calendar!
            • Re: ls1 vs 3800
              The time allowed for the ECT to reach closed loop enable is 2 minutes. In cold area's (Canada) it can be set as high as 5 minutes. The temp it has to reach in warm area's is 58 * F. The 2 minutes is way more time then it needs to get there.
              You should also turn spell check on.
