so for a few weeks now I have been having this wierd idle issue, sometimes it wants to die while others it wants to idle at 1500-2000 rpm. With the way it comes and goes I decide it's likely the idle air control valve sticking and besides the throttle body could use a cleaning.
Take everything apart, no biggie. Clean the throttle body, change out the IAC. clean everything up (or so I thought) and put it back together and crank the car, first start is hard then it starts up but idles funny. Cut it off, crank it up again, walk around to the front of the car to see water running dripping down the front and flat running down the front when I give it gas.
Take it all back apart and there was one little peice of old gasket I missed which allowed water to not only go down the front of the engine but to also get sucked down the intake.
Hoping I'm not totally screwed I pull all the plugs which were all damp and turn the engine over for a few seconds at a time with the plugs out. Let it sit put it all back together and crank it up. Car runs fine, even feels a little peppier, only problem is when sitting at idle I got this nice white cloud of smoke and when going down the road if I get on the gas hard I can make my own smoke screen.
So now I'm :twak: ing myself feel a little
and have to try to find a decent shop on monday as I just don't have the time or energy to pull the heads and change out the head gasket.
For the last 8 years I have done all the work on this car myself with no problems this time it's gonna cost me bigtime. Ugghh!! Ok just needed to vent. If anyone knows a good shop in or around Plano Tx feel free to speak up.
