What have u done to ur camaro/firebird today? - FirebirdV6.com/CamaroV6.com Message Board
This topic is closed.
  • #61
    Re: What have u done to ur camaro/firebird today?
    Originally posted by espey_16 View Post
    I replaced my rear main seal/plate seal, put my flywheel back on, and unsuccessfully tried pulling my old pilot berring out.
    Is it a bearing or bushing? If you havn't screwed it up yet, pack it full of grease and take a dowel rod (metal) and hammer it in. The grease will hydralic the bushing out.
    • #62
      Originally posted by 96RS Alex View Post
      Put the V6 away and drove the SS instead...
      WTHBBQ?
      10 different grades of gas?
      I'm guessing that's the usual 3 grades with two mix choices, times two for cash vs. credit.
      I washed my car and put 16 gallons of regular gas into it (I was running really low). I'm still nursing the coolant overflow reservoir leak until I can get part #10188032. She gets about a cup of coolant each morning.
      I solemnly swear I am up to no good.
      • #63
        87, 89, 93, 94 octanes and diesel. Diesel is usually always notated with green.
        1995 Pontiac Firebird
        • #64
          Originally posted by Fbodytrinity View Post
          Finished putting on new rear shocks that i have needed for the last 2 years just to lazy to do it... and no i didnt get anything cool just the regular monroe sensa trac ones
          I got the same ones...gives a nice ride
          • #65
            i got an amazing deal i went to my dads buddies shop and put new head gaskets and intake manifold gaskets on for 380 and thts including parts!!
            • #66
              Washed the V6, tucked it away and drove the SS again. Good thread ! :D;):cool:
              Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
              • #67
                It was a bearing, I tried a wood dowel and grease, then wet TP, and neither method worked so I got pissed and jammed a screw driver in the needle bearings and pried them out, and called it a day. I ordered a pilot bearing removal tool from overstock.com and I'm still waiting on it. If that dosnt work, ill probably take a dremel to it.
                1997 Chevrolet Camaro
                • #68
                  Yesterday, was about to put outer tie rod ends on but discovered my problem was my steering rag joint, put a new stock spoiler on (my gf backed the car into a tree a year or 2 ago), and a new washer fluid resivoir. Tonight, gonna fix my exhaust leaks at the egr, didn't have the gaskets till today, my temporary cardboard/rtv gaskets have failed finaly.
                  • Andy H
                    Transmission removal help!!
                    by Andy H
                  • 2.8 Bird
                    Abs inop
                    by 2.8 Bird
                  • fishin
                    by fishin
