repainting my trailer... - FirebirdV6.com/CamaroV6.com Message Board
  • repainting my trailer...
    Ive got a trailer, with a 20 ft deck, and a 3 ft storage cabinet up front with a tire carrier, and then the tongue length, probably about 26ft long total, dual axle, dove tail.
    Its all metal, the deck is diamond plate that has been painted twice since it was built about 5-6 yrs ago.
    Im needing to sand the whole thing down to knock off any little rust and paint that is chipping off. My buddy used it as his race car trailer, and painted a few #'s on the backside of the storage, and some devils holding a checkered flag on the doors... He used like canvas paint, and I need to take a grinder to get the paint off of those.
    After that Im painting it, it will be mostly dark grey, with a little black on the side rails and whatnot.
    What paint should I use, I planned on using rustoleum, thinning it out a little with some thinner, and rolling / brushing it on.. but is there a better paint that will hold up to the abuse of sitting outdoors, and getting used alot?
    Im updating it with all LED' tailights, and safety reflective tape on a few parts.
    Thanks
    *Matt
    Re: repainting my trailer...
    idk but it sounds like its gunne look bada$s when your done
      go to sherwin williams paint store and ask for this specific paint....( i know this is useless cuz I don't remember what it's called) but it is specifically for metal, rust etc. And I have used it to paint a couple of industrial trucks and it worked really well. They should know what it is, just tell them its for metal. it is like 150 bucks for a 5 gallon bucket.
      #1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
        Get some 2 part Epoxy paint. It will be more durable.
          Where do you get this, never heard of it
          *Matt
            way overkill... I probably wont need more than a gallon of each(color), if that.
            *Matt
              i heard walmart has a deal on spray paint...in a can...
              Team NoVa
                psh if that were the case, id park it in the ghetto for 20 minutes, and it would probably get a "tagger" paint job.. That's free!
                *Matt
                  and looks mighty fine when you clear coat over the tag.
                  Team NoVa
                    Most paint stores.
                      Maybe if I prepped the trailer's surface with trans-x it will withstand all weather conditions and all the abuse I can throw at it.
                      *Matt
                        that sounds risky, that much trans-x in one place could cause your trailer to turn into a truck and become optimus prime/bobby from the brady bunch...
                        Team NoVa
                          I saw trans-x today at the store and I giggled a little bit...
                            I sprayed Rustoleum on my car trailer with an automotive spray gun about 15 years ago and it's still in good shape. No rusting or pealing. Only kicker is you can't thin it, you need to turn the air pressure up and spray it like it comes out of the can (did not use spray cans).
                              Jesus, do you keep it indoors and under a protective cover, lol....
                              15 years, Im lucky If I can go 15 days without scratching mine.
                              Although, you probably have a wood deck with helps, i have a steel diamond plate deck.
                              *Matt
