twin turbo 89 iroc - FirebirdV6.com/CamaroV6.com Message Board
twin turbo 89 iroc
  • #31
    Re: twin turbo 89 iroc
    Originally posted by ssms5411 View Post
    Looking good , whos painting it?
    friend of mine who used to work in the body shop in town, he does really nice work, only reason he dont work there anymore si he was offered a job at a different place for 3x as much money
    car goes in for the black epoxy primer on july 13th , then goes back 2 weeks later for the base/pearl/clear coats
    the wife likes blue more then red so to keep her happy im using blue pearl instead of red , same concept though int he shade and low light conditions the car will be jet black , in direct light or sunlight the blue pearl will stand out like the picture i posted above
    • #32
      Cool car, nice build.
      • #33
        http://www.youtube.com/watch?v=GjfmkWAB5Jw
        might take it out tomorrow and get some really good driving vids , couple friends wanna take a trip up the mountain to the ski resort and back , if i go should get some good footage
        • #34
          • #35
            • #36
              its been almost a year
              anyways new engine in the iroc , decided it was time to stop playing with stock engines
              http://www.youtube.com/watch?v=s7uZzE8PESY
              if my photobucket wasnt out of bandwidth id posta picture of the new engine
              basically its a 353 sbc
              aftermarket bushed rods
              speedpro -10cc dished pistons
              64cc 200cc runner heads flowing just shy of 300 cfm
              232/236 cam with a split set of rockers
              hsr intake
              nx direct port nitrous kit
              twin gt3582's ( still has the old gt3076's on it for now )
              • #37
                Sounds nice , your GT3582's are they the Garrett GT35R's? I have mine still sitting in my garage. Their expensive but work very well. Whats the specs of the turbos? What times are you going for?
                • #38
                  thanks , the gt3582's are the chinnese versions 61mm inducer 82mm exd with ptrim turbines instead of standard gt35 turbine wheel , not the best turbos but they will work just fine, eventually i think ill be switching to a big single turbo 88mm +
                  the direct port nitrous system is mostly for the wow its got nitrous on it when ppl look under the hood as the lowest i can jet the system is 100 shot , prolly only use it when i run the turbos at 5 psi for the street or to spool a very large single turbo
                  goals are fairly simple
                  #1 make it into the 200mph club at bonneville
                  #2 low 9's high 8's at the drag strip
                  only a couple things left to do to the car , install the dana 60 rear , finish the cage, and install the parachute , and finally get the car over to the body shop for paint
                  • #39
                    http://www.youtube.com/watch?v=XRqVFnn3Tck
                    • #40
                      Sounds great, I know mics on camera's suck but I bet it sounds outstanding in person.
                      • #41
                        its update time
                        • #42
                          since i never got to post them since my pb was down
                          • #43
                            never got to finish it yesterday , i just had to give up for the day and head home so this is as far as i got
                            wensday ill finish that up , next weekend , the log headers and twin 57 turbos get pulled so i can install the up and forward headers , and install the twin 66mm turbos
                            • 187shark
                              by 187shark
