Originally posted by 3.4 slow to go: </font><blockquote>quote:</font><hr />Originally posted by SilverRS96: jack it up!
is it 2 or 4wd? My wife wants her 95 Blazer jacked up, but there aren't all that many lift kits for the 4wd versions. </font>[/QUOTE]ZR2s are all 4x4.. They come standard with stiffer frames, 3.73 gearing, wider & stronger axles, etc etc.
There are lift kits for 2wd - what are you looking for? How much lift? You can always do a body lift and cheap out that way...
Mustangs.. Come to the darkside...<br /><br />The dark side is the path to the shadow of greed. =D
You can do a spindle lift, 3" and 3.5", which wont change the suspension geometry really at all, it will just lift the truck and not change the ride quality/style.
Coil lift will make it ride a lot stiffer, but you will have to change your shocks.
To lift the rear you'll need an add-a-leaf setup.
Then theres body lift, like I said [img]smile.gif[/img]
