Hey, I was just wondering if anyone on this board can offer me any advice on locating good Jeep Forums. Mainly, I'm interested in info on my XJ. Done a few searches, but I wanted to see if anyone had some feedback...thanks for the help..
Jeep Stuff
FirebirdV6.com/CamaroV6.com Administrator
Stupid is rewarded with the ban button.
Official Avatar Nazi according to Meatyshells :D
Re: Jeep Stuff
hey, hows it goin?? Yeah, i'm trying to find the answer to my drivetrain vibration/clunking noise.. ive had the front axle apart now three times in two weeks.. figured its time for some additional help and was just wondering what forums are out there that have good tech support..
thoughts????Phill<br /><br />95 camaro... need money for turbo project... <br />94 S10 Blazer - winter beater - infinity system to be installed soon<br /><br />\"The man who says it cant be done should not interrupt the man doing it...\"
Re: Jeep Stuff
Originally posted by camaroman1181hey, hows it goin?? Yeah, i'm trying to find the answer to my drivetrain vibration/clunking noise.. ive had the front axle apart now three times in two weeks.. figured its time for some additional help and was just wondering what forums are out there that have good tech support..
thoughts????
Have you done the normal searches on www.naxja.org and www.jeepforum.com ?
SteveFirebirdV6.com/CamaroV6.com Administrator
Re: Jeep Stuff
http://forum.camarov6.com/showthread.php?t=84297&page=2
i'm the guy with the jeep questions that hijacked one of your earlier threads.. lol..
Yes, I tried rotating tires too... didn't help. The issue started off as only a low speed vibration though. So I kind of ruled out tires. My thinking was that at speed, there is more momentum that would pronounce a tire issue, and at low speed (below 25 mph), there isnt enough mass moving fast enough to create the situation i have. In fact, once the problem starts up, its worst at about 5-10 mph.
The noise is linked to vehicle speed, not engine speed. It's also getting worse. Its starting to rear its head in the form of a full time light vibration. The low speed noise is more of a clunk. I've had it apart 3 times thinking its the wheel joints or i got a bad wheel bearing hub assembly. But everything is tight and moves as it seemingly should. I cant seem to find anything loose. Quite frustrating. I'm about at the point where I'm goign to drive it until something just breaks. At least I'll know what to fix if soemthing is spewing fluid or smoking.Phill<br /><br />95 camaro... need money for turbo project... <br />94 S10 Blazer - winter beater - infinity system to be installed soon<br /><br />\"The man who says it cant be done should not interrupt the man doing it...\"
Re: Jeep Stuff
oh, and thank you for the links to the jeep forums... those are what i was looking for! :)Phill<br /><br />95 camaro... need money for turbo project... <br />94 S10 Blazer - winter beater - infinity system to be installed soon<br /><br />\"The man who says it cant be done should not interrupt the man doing it...\"
Re: Jeep Stuff
Ahhh... have you checked to see if the bushings are dead? axle or body side for the control arms?FirebirdV6.com/CamaroV6.com Administrator
Re: Jeep Stuff
well, i have not checked too much into the bushings.. checked the control arms for play or any apperent issues, but they all seemed ok. I do have a track bar that is starting to go out. I've been ruling out suspension issues due to the noises being speed sensitive, on all types of pavements, smooth, rough, and goign i na straight line or around corners.Phill<br /><br />95 camaro... need money for turbo project... <br />94 S10 Blazer - winter beater - infinity system to be installed soon<br /><br />\"The man who says it cant be done should not interrupt the man doing it...\"
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 day ago
