Search problem - FirebirdV6.com/CamaroV6.com Message Board
Search problem
  • Search problem
    Every time I search I get this...is this happening to anyone else, or is it just me for some reason?
    Fatal error: Allowed memory size of 33554432 bytes exhausted (tried to allocate 35 bytes) in /home/cv6admin/public_html/forum/search.php on line 1155
    auto, aluminum driveshaft, Fast Toys Ram Air, !air silencer, smoothed lid, Pacesetter shorties, 2 1/2" exhaust, !cat
    New Time:
    15.11@91.14
    Team 3M Mafia
    New Times coming soon
    Re: Search problem
    works fine for me
    Follow me!
    Or this
      Re: Search problem
      I googled your problem and this showed up, so hopefully that helps.
      http://drupal.org/node/283579
        Re: Search problem
        From that link it sounds like a server side problem. Is it just one thing you're trying to search specifically or just anything?
        TEAM C6V6
          Re: Search problem
          it works for some things but i tried to search I think it was "car died" then just now "car wont start" and it's still doing it
          New Time:
          15.11@91.14
          Team 3M Mafia
            Re: Search problem
            seems that it just doesn't like the word "car" just searching car yields the same results. and taking car out of search terms makes it work
            New Time:
            15.11@91.14
            Team 3M Mafia
              Re: Search problem
              This is a common problem for php scripts that are resource intensive (like this forum). The error indicates that the php configuration on the server is restricted to 33,554,432 bytes aka 32 megabytes and that this php script (search.php) is trying to exceed that maximum memory allocation restriction. The reason it happens with some searches and not others is due to the memory usage associated with the execution of that particular search. Say a search for the word 'car' yields 20,000 results, this will use a lot more memory than a search for an obscure word.
              To fix this issue more memory would have to be allocated in the php configuration. Someone who runs the server would have to edit the php.ini configuration file and set "memory_limit" to something higher than 32M.
                Re: Search problem
                Well Duh! :slap:
                TEAM C6V6
                  Re: Search problem
                  I haven't had any problems with it.
