This is a common problem for php scripts that are resource intensive (like this forum). The error indicates that the php configuration on the server is restricted to 33,554,432 bytes aka 32 megabytes and that this php script (search.php) is trying to exceed that maximum memory allocation restriction. The reason it happens with some searches and not others is due to the memory usage associated with the execution of that particular search. Say a search for the word 'car' yields 20,000 results, this will use a lot more memory than a search for an obscure word.
To fix this issue more memory would have to be allocated in the php configuration. Someone who runs the server would have to edit the php.ini configuration file and set "memory_limit" to something higher than 32M.
