problems with this site help me... - FirebirdV6.com/CamaroV6.com Message Board
  • problems with this site help me...
    Ok Im haveing problems trying to
    get in to the message board anyone
    know why?? Keep getting a "site not
    avaliable" after I click on the message
    board link. Its random that I'm able
    to get in like this time and probalby
    wont be able to get back in to see my
    question get answer but I will keep trying
    like always.
    thanks ahead benavidez19
    <a href=\"http://www.cardomain.com/id/lucky19\" target=\"_blank\">http://www.cardomain.com/id/lucky19</a>
    http://www.firebirdv6.com/dnserror.html
    We are aware that some FirebirdV6.com/CamaroV6.com members have been having difficulty accessing the message board server due to an Internet DNS misconfiguration. This document explains how to use the Windows hosts file in order to teach your computer the correct Internet address of the message board servers. Following these instructions should allow you to access the message boards as you normally would under any circumstances. Linux instructions are also included, and may also work with similar UNIX variants.
    Windows 95 / 98 / Me
    1. Load the file C:\WINDOWS\hosts into a text editor (Notepad is suggested).
    Note: If your Windows install directory is not C:\WINDOWS, use your install directory instead.
    2. Add the following text to the bottom of the file on a blank line (in Windows 95, 98, or Me this file may not exist or may be blank. In this case, simply add the line anywhere in the new file):
    64.246.34.35 www.camarov6.com
    Note: It is recommended to seperate the IP address and domain name with a tab instead of a space.
    3. Save the file and reboot your computer.
    Windows NT / 2000 / XP
    1. Load the file C:\WINNT\system32\drivers\etc\hosts into a text editor (Notepad is suggested).
    Note: If your Windows install directory is not C:\WINNT, use your install directory instead. Windows XP is often installed to C:\WINDOWS.
    2. Add the following text to the bottom of the file on a blank line:
    Note: it is recommended to seperate the IP address and domain name with a tab instead of a space.
    Linux
    1. As root, edit the file /etc/hosts into a text editor.
    this might help, also available on the main fv6 site (if you cain get back on here to read this)
    2013 Ram 1500 Big Horn
    94 comero 3.4
      i have been having a lot of problems trying to get on any camarov6.com address also but firebirdv6.com works. kinda weird and kinda sucks cause the message board is on the camarov6.com address but its only at my school computer so i figured it was just the server.
      2000 3.8 A4 Pewter Camaro
        ^^^^ i have the same problem.. my home computer wont load for a day or two at a time, but at work it loads right up. and this computer worked fine at other locations (my parents house, 2 different apartments at school)... the firebird site will load, but then i cant access camarov6... even going thru firebird...
          exact same problem as me :\
            Well it seems to have work thanks 3.4 slow to go.
            • Andy H
              Transmission removal help!!
              by Andy H
            • 2.8 Bird
              Abs inop
              by 2.8 Bird
            • fishin
              by fishin
