okay guys, I see it alot "How do i install a Jet Chip" so i figured since I sold mine I would make a write up on how to install it while i was taking mine out.
1.) Disconnect the battery! I can't stress that enough you can harm the chip and your PCM
2.) Take a 7MM socket and unscrew the bottom plug in the PCM
should look like this
3.) Make sure you are free from static (I bought a static braclet at raidoshak 10 bucks) and plug in the jet chip then take a large flathead screw driver after the jet chip is plugged in and tighten up the middle screw DO NOT OVERTORQUE!
4.) Last step your almost there! just plug the PCM in to the Jet Chip take the 7MM you used earlier and screw the bolt into the Jet Chip once again do not overtorque just hand tighten it!
then your done take the car for a drive let it get used to the chip and have fun!
This whole install shouldn't take you more than 10 min. or so..
I hope this helps someone!
