How To: Jet Chip Install - FirebirdV6.com/CamaroV6.com Message Board
This topic is closed.
This is a sticky topic.
  • How To: Jet Chip Install
    okay guys, I see it alot "How do i install a Jet Chip" so i figured since I sold mine I would make a write up on how to install it while i was taking mine out.
    1.) Disconnect the battery! I can't stress that enough you can harm the chip and your PCM
    2.) Take a 7MM socket and unscrew the bottom plug in the PCM
    should look like this
    3.) Make sure you are free from static (I bought a static braclet at raidoshak 10 bucks) and plug in the jet chip then take a large flathead screw driver after the jet chip is plugged in and tighten up the middle screw DO NOT OVERTORQUE!
    4.) Last step your almost there! just plug the PCM in to the Jet Chip take the 7MM you used earlier and screw the bolt into the Jet Chip once again do not overtorque just hand tighten it!
    then your done take the car for a drive let it get used to the chip and have fun!
    This whole install shouldn't take you more than 10 min. or so..
    I hope this helps someone!
    2001 Camaro 3.8 A4
    1991 3000GT VR4
    2001 Mitsubishi Eclipse GS
    Re: How To: Jet Chip Install
    I would like to know how to fry my PCM by having the battery connected please?
    You dont have the rubber gasket that protects the PCM from water damage... I couldnt get mine back on today, so I said Fuk it
    Dont I wish I were cool like you all and had a Jet Stage 2 chip!!! FTW
      with the battery hooked up you ALWAYS have a better chance of shorting something out
      2001 Camaro 3.8 A4
      1991 3000GT VR4
        good writeup. With minimal modifications done would you reccomend a mail in tune like pcmforless or a jet chip?
          Great write up
          now all i need is a jet chip
            or deploying an air bag..
            or blowing up the battery..
            etc.. etc..
            I just wanna know how I can destroy my PCM so I will avoid it.. lol
            I'm sure I could think of alot of ways :)
              MAIL ORDER TUNE > Jet chips
              plus you get lifetime updates
                Where is the PCM located at on the 3.4L Firebirds?
                  Anyone? I have heard it is under the dash from some and I have heard it is under the passenger side kick panel is either true? Is there any difference between a 94 and 95 PCM on an A4 camaro/firebird?
                    THANKYOU THANKYOU I just got mine yesterday for my 98 fbird i am putting it on tommorow bu my car is already parked for winter so i will not be able to see results until approx march
                    • Manimal
                      Coil springs
                      by Manimal
                    • Manimal
                      Newby here
                      by Manimal
