fastest all motor v6 built camaros - FirebirdV6.com/CamaroV6.com Message Board
  • #46
    Re: fastest all motor v6 built camaros
    ya but they are getting their stroker from C.O.M.E racing arent they? which is something crazy like 3gs?
    • #47
      The new Billet Crank is 1800. I might just go with that and use the guts from a GTP (Pistons and Rods) and get new bearings all around. This is all in my head though, as my small military income does not satisfy my hunger :(
      • #48
        ruffle lulz. $1800 for a crank? You need to get your head checked.
        • #49
          It isn't the fastest all motor, but I did hold the NHRA SS/DS and SS/CX National records until "Life" got in the way and I parked the car. There are other cars running in Comp and lighter V-6 Super Stock classes that run quicker ET's
          It is a 277 cu in 750 Holley in SS/DS it's weight is 3185 and in SS/CX it ran at 3400 lbs in the vedio I was running a 1.98 low gear powerglide. I have switched to a 3 speed proflite w/a lower gear and gone quicker. The 60's dropped from 1.34 to 1.28
          I never had it on a RW dyno, but on our engine dyno it made 660 hp.
          http://www.youtube.com/watch?v=eZPI6eCN8pE
          http://www.youtube.com/watch?v=ydKaD...eature=channel
          Adger smith
          Adger Smith Performance Engines
          2802 W 7 th st
          Texarkana Tx
          903 794 7223 shop
          adgersperf@aol.com (E-mail)
          www.adgersperf.com (no e-mail on site)
          • #50
            Launching at 7k and shifting at 9.4k rpm? What kind of setup do you have for the heads and how many passes does it last?
            96 White M5 Camaro. Manual everything. Magnaflow cat, dynomax dual outlet axle back. Swapped to a disc rear with 3.42s and a torsen differential, kyb gr2 rear shocks, moog rear endlinks.
            • #51
              thats a serious set up. props
              • #52
                It's not the heads that wear out it is the springs. The near .900 lift intake springs go down in pressure pretty quick. Usually rotate them to the ex side after about 12-15 runs. That is every couple of races. When we ran 18 degree heads we turned them 10,200 and they liked it. The splayed valve makes more power and at not so high an RPM. They increased torque. It is no different than any good Comp engine. Wish I could figure out the picture deal. I'm not too sharp with these forums. :~(
                • #53
                  Adger smith
                  2802 W 7 th st
                  Texarkana Tx
                  903 794 7223 shop
                  Wich engine are you running? It's not a 3800 Series 2 is it? thats 660 crank ponies all motor? no boost or juice. . .Im shooting for just 300 at the crank i think im doing it wrong. . .what where your 1/4 mile ETs?
                  • #54
                    It is a GMPP bowtie block version of 4.3 The best we have run is the 9.68 run @ 3185 lbs
                    No Nos, just a class rule required 780 vac carb. We did the 9.68 testing the new DC (david cook) Carbs 780 (3310) over the tried and true 750 (4779) Davince Holley.
                    277 cu in with 660 Engine HP.
                    Picture on our Dyno: http://adgersperf.com/dyno.htm
                    • #55
                      Nice, I kinda figured it was one of the bowtie blocks. Gotta love the fact that we used to have all motor V6's in NASCAR...
