i have read all about power braking and flashing the converter, and i still need some help. the next time to the track i will be on drag radials (i think i read i should try 22 psi) with my 2800 stall TC. should i rev it up to 2800 and punch it from there or should i flash the TC? i will be on warmed up drag radials so what should i do? my car is an automatic with 3.42s
teach me how to launch
you got mail nino [img]graemlins/fluffy.gif[/img]1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
yep as soon as i break in the power pack i plan on doing a run here in san antonio then a week later go up to houston if not the next day. i am still waiting for my parts to come back from tom, so i prolly wont hit the track till next month. [img]graemlins/burnout.gif[/img]6s.......under the hood or under the belt, they just dont cut it.
OK ok, I'll tell ya.
What drag radials do you have?
Nitto's seem to work well at 22 psi
B F's weem to work 16-18 psi
Nitto's need a longer burn out than bf's
Pump up the air in the front tires to 40 psi.
Stall it to all hell (as high as it will go without spinning the rear tires) and then on the last yellow floor it (make sure you release the brake pedal too :D )Race car - gone but not forgotten - 1997 firebird V6
My best results with street tires were found with 30 psi in the rear and 40 psi in the front.
These were street tires and nitrous runs.
Quick snap of the rear tires.
Not a long burn out or even a short burn out.
255 50 16's in all four corners.
I think I went 13.6? with no tire spin at all with the above track methodRace car - gone but not forgotten - 1997 firebird V6
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
