Got challenged by a WRX at the track when I had my dads LS1 - FirebirdV6.com/CamaroV6.com Message Board
  • Got challenged by a WRX at the track when I had my dads LS1
    A guy had a WRX with a upgraded turbo runnin 18psi with intake and exhaust wanted to race me. I had a 98 Trans Am, so I said ok and we had the SAME exact R/T which was .562 and I ran a 13.07 at 104 and he ran a 13.19 at like 105. I won by like 3/4 of a car. The Trans Am just has exhaust, Sun Coast Raptor hood with airbox, 3500 stall converter, and a cutout. Plus I had a damn full tank of gas so I would have hit 12's N/A if it wasnt full. Oh well
    Past Ride
    1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
    (If you dont know me, you haven't had a V6 long enough)
    Current Ride
    2006 Mitsubishi Evolution GSR
    www.myspace.com/shane1015
    very nice. WRX's only hit low 13s with 18 pounds of boost?! what psi do they run stock?
      i want to test against them in a camaro as well [img]smile.gif[/img] with SS hodd, airbox, kn filter and SLP CAI and flowmaster exhaust
        <blockquote>quote:</font><hr>Originally posted by TheBeast:
        very nice. WRX's only hit low 13s with 18 pounds of boost?! what psi do they run stock?<hr></blockquote>
        It was a bigger upgraded turbo and stock boost is 14psi
        Past Ride
        Current Ride
          the thing about the wrx is that it is all-wheel drive, meaning very little wheelspin off the line. on turbo'd motors, you can get lots of power just by adding intake, exhaust, wastegate, adj. fpr, and intercooler. besides it being a featherweight, I don't see the problem. just do more **** to the TA. maf sensor, tb, intake manifold, headers, shift kit.
          2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
            Stock boost is about 12 PSI, they run a 14 flat stock is what ive heard so a 13.1 is pretty good. My friend has a WRX with a boost controller, blow off valve, turbo timer, full exhaust and intake on 23 PSI, That f*C*er is so fast. We are taking it out to the track tonight. I will let know what he runs.
              yikes would have warned, you a decent amount of car WRXs at OSW are running low 13s, something you may want to keep an eye on. I would have been pretty nervous, racign a car that I do nto race consistantly. YOu should see what you can do to drop another .5 off your ET on your v6, just so you can tell your dad you can beat hime with a v6 [img]smile.gif[/img]
              Ugh... I have fond memories of taking the dad's car to OSW, spinning through first on first 3 runs, then getting only slight wheel spin in first on the last run to get the time posted in the sig, then the entire hydraulic system on the clutch crapped out on 408 the next day. Nothing like calling your dad up telling him, the clutch system went out on his car when it has less then 7k on the clock. Good thing he never found out I took it ot hte track [img]smile.gif[/img]
