What should I run on the 1/4 mile - FirebirdV6.com/CamaroV6.com Message Board
  • What should I run on the 1/4 mile
    Here's what I've done to her:
    2001 Firebird A4
    Borla Catback Exhaust
    RK Sport Headers
    555R Drag Rear Tires
    4.1:1 Rear End Gears
    Lower Control Arms
    Panhard Rod
    Whisper Air Lid
    Fast Toys Ram Air
    Hypertech 160 Thermostat
    Hypertech Power Programmer 3
    93 Octane all the time
    And every appearance mod out there
    What do you all think?
    2001 A4 Pewter 75th Anniversary W68 Firebird<br />1997 Dodge Ram Extended Cab 360 CID<br />1996 Ford Explorer V6<br /><i><b>Any number you can think of, I can think of one higher.</b></i><br /><a href=\"http://www.criesmusic.com\" target=\"_blank\">www.criesmusic.com</a><br /><a href=\"http://www.mp3.com/beneaththestage\" target=\"_blank\">www.mp3.com/beneaththestage</a><br /><a href=\"http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar6.jpg\" target=\"_blank\">http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar6.jpg</a><br /><a href=\"http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar4.jpg\" target=\"_blank\">http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar4.jpg</a><br />AIM: Guitarchitect201
    15.0-15.1@89-90MPH
      You should hit the 14 mark with no problem as long as you get a good launch.
        I'm wanting to hit 14.3. My list of mods is already in this thread, so what you do you all think I should do to hit a low 14? I was thinking a Yank 3500 stall? I'm not going to go with a shift kit cause the HPP3 provides a very firm shift already. My main advantage right now is the 4.1 gear. What does every think I should do to get my ET down.
        Thanks
          3000-3500 stall converter, transgo shift kit, torque arm, 1.9:1 roller rockers, aluminum driveshaft. the converter will get you better acceleration, shift kit will use even less clutch engagement than you do now, putting power to the ground longer and wasting less of it trying to shift soft, roller rockers will help the heads breathe better since you have intake, exhaust, and headers, aluminun driveshaft will let you put more power to the ground by weighting less and also it will let you rev quicker, and the torque arm will help w/ off-the-line traction, helping you accelerate quicker.
          [ May 28, 2002: Message edited by: Patrick Javert ]</p>
          2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
            4.10 Gears in an automatic!! WOW!
            uhh you will be in overdrive by the time the 1/4 is over...
            and a converter with 4.10's better get some slicks cause there wont be any traction..
            i think 4.10 are too much for an automatic..
            dont expect to run low 14's with out a stall
            Jeff W [img]graemlins/thumbsup.gif[/img]
              definatly not 14.3. I have same mods plus a lil more minus the 4.10's i have 3.42's and I run 14.92 at 90mph N/A. Check out my mods in sig and times
              [ May 28, 2002: Message edited by: Shane ]</p>
              Past Ride
              1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
              (If you dont know me, you haven't had a V6 long enough)
              Current Ride
              2006 Mitsubishi Evolution GSR
              www.myspace.com/shane1015
                4.1 gears is the only mod that has shown very notieable gains. It drives like a completely different car. I honestly think it's the best mod that I've done - but that's me and my opinion. By the way I do have slicks Nitto 555R. I am getting a 3500 stall converter, torque arm, and aluminum drive shaft. With these additions I don't think it would be unreasonable to run a 14.5 quarter.
                  Since Shane ran a 14.92@90mph with 3.42's I would think you could see a 14.5x-14.6x if you hook good off the line. Also where does you car shift? My cousin has 4.10's in his '92 and he shifts at 6000rpm so he's able to run the 1/4 in just 3 gears. If your car shifts below that on ever gear your going to most likely end up finishing in 4th gear like NBMA4V6 said. Which if that happens even though you have a high ratio in the rear your times are going to suffer. I mean its just not a gear you want to be in for acceleration and 1/4 mile testing. Just keep that in mind if you don't run like you want to the first time out. Just figure out a way to finish in 3rd and you should do fine. [img]graemlins/burnout.gif[/img]
                  <a href=\"http://www.geocities.com/MotorCity/Street/6330/VicCamaro.html\" target=\"_blank\"><b>*1997 Silver Camaro A4/3.08*</b></a><br /><b>Best 1/4</b>(December 17, 2003)<br />Race weight: 3580lbs w/driver <br />RT: .396 1/4: 14.93 60\': 2.08 MPH: 89.73<br /><b>Mods</b><br />&gt;Flowmaster 80 muffler (muffler only) &gt;Homemade cold air with K&N 1000cfm cone filter &gt;Trans-go Shift Kit &gt;2400-2600 TCI converter<p><b>*1969 Camaro SS*</b><br />*502ci (92-octane pump gas)<br />*2-speed powerglide<br /><b>Best 1/4:</b>1.34 60ft 9.78@138.12mph (Aug 16, 2003)
                    I'm assuming your PCM is programmed for the gears using the Hypertech. So your shift points are correct and top speed is still 118 or more. What kind of lower control arms and panhard rod do you have? You should be hitting 14.8 or better with those mods. I'm assuming the car and the track are in good shape. What's the track's elevation? I know you got some hills down in KY, since I've been there. If it's close to sea level, then shoot for 14.8s or better. Any worse and you have some problems to work out.
                      I have aluminum lower control arms, and a BMR Adjustable pandhard rod. The car is in great shape, only 12K on her. Since the HPP3 didn't have the 4.1 gear option, I had to trick the PCM and tell it I had 24" tires, now it's only 4-5 MPH off at 65. Shift points - I can tell it to shift anywhere I want to. My shift points are now set at 6400 which with the gears being a little off is really about 6100. Track is at 550 above sea level, it's in good condition. I really think with a stall coverter and torque arm I can hit low 14s.
                        fyi nittos arent slicks they are drag radials.
                          Yea with Nittos I think a 14.6 is what you would run. Make sure u get them Nittos hot!! Also stall the converter up to about 2K or so.
                          Past Ride
                          Current Ride
