Stuck at 14.2@99mph with the 75 shot - FirebirdV6.com/CamaroV6.com Message Board
  • Stuck at 14.2@99mph with the 75 shot
    At least I'm consistent... too bad it wasn't brackets tonight. My first 3 passes:
    R/T ... 1.160 <--sit on the light much? ;)
    60' ... 2.265
    330 ... 6.107
    1/8 ... 9.282
    MPH ... 78.66
    1000...11.951
    1/4 ...14.230
    MPH ... 99.40
    R/T ... 0.880
    60' ... 2.205
    330 ... 6.144
    1/8 ... 9.314
    MPH ... 78.82
    1000...11.982
    1/4 ...14.257
    MPH ... 99.29
    R/T ... 1.046
    60' ... 2.280
    330 ... 6.105
    1/8 ... 9.278
    MPH ... 78.72
    1000...11.949
    1/4 ...14.228
    MPH ... 99.52
    That was on street tires. Brought my NEW Draglites with nittos on them, but forgot the lugs to put them on with... doh!
    Tranny is an M5, SPEC stage 2 clutch w/lightened flywheel. The setup is a custom NOS/Edelbrock wet system. Kumho tires, 255/50. I wasn't having much trouble on the launch, 2.2s is respectable for street tires. On the 75 shot I didn't seem to be spinning much down the line, although I may have spun going into second, hard to tell. I should be seeing 13s on the 75 shot and I also think the MPH should get to the 100s (one pass was at 99.97)
    What's going wrong here?
    -<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
    i guarantee if you had some sticky tires you wouldbe like sub 2 60 ft which would be 13s easy good job with a 75 shot [img]graemlins/thumbsup.gif[/img]
      u need better 60s and u might be running to rich on the shot, look more into those jets you were talking about [img]smile.gif[/img]
      [ June 15, 2002: Message edited by: Tiago NOS'd Bird ]</p>
        posted by 96beastv6:
        You're launch sucks
        [img]graemlins/rofl.gif[/img] j/k.. but seriously, you need to powerbrake and bring the rpm's up before you take off. Your 99mph trap is awesome. You should be hitting at least a 13.9 et.
        2004 CE Corvette 10.86@132mph
        2011 Cadillac CTS-V
        2006 Mitsubishi Eclipse GS
          <blockquote>quote:</font><hr>Originally posted by Shirl:
          You're launch sucks
          <hr></blockquote>
          Thats what happens when you're used to launching on the drag radials, then buy some new weld draglites for them and forget the special lugs to put them on with, so you're stuck with the street tires. DOH!
            With my 75 shot i pull a 13.56 with a 1.7 60 foot and when i was on street tires i puled a 13.9 with a 1.9 60 foot
              Yeah, nothing personal but it is in your launch.
              Your mph is perfect!!!!
              I run 13.0 at 99 w/ a 1.8 60 ft w/ 323 gears on a 75 tnt/ nos hybrid kit
              It is all in the launch
              Typically for every .1 in the 60 foot that is like .2 in the 1/4
              So lets say you start seeing 2.0 or even 1.9 60 ft's That could be .4 or maybe .6 quicker (in theory)
              So a 13.8 or 13.6 should be obtainable in your car
                try a aluminum or carbon fiber driveshaft. you'll be able to get up to your powerband quicker and put more power to the ground. I suggest aluminum since carbon fiber is 800 bucks. that, and if you're losing traction w/ your tires, get ZR1 rims(17x11) w/ 315-30-ZR17 tires on them. w/ lsd, you won't be spinning tires into smoke anymore.
                  315 30 17's?
                  He wants some traction.
                  Sure they are wide but there is no sidewall for flexing.
                  That is a tire for ahndling and no traction.
                  My 275 40 17's used to grab in overdrive at about 80-85 mph.
                  I have cut low 1.7's (1.731) with a 245 50 16 nitto drag radial.
                  That tire is only 9.64 inches wide
                  I now run a et street 26 x 11.5 x 16 which are 11.5 inches wide and I have seen a best of 1.630
                  You are talking about a 12.4 inches wide tire with no sidewall.
                  You do not need the widest tire out there.
                    You guys just won't leave that lauch alone will ya? [img]smile.gif[/img]
                    Yes, I know I'll have better 60s with drag radials, thats why I bought them a month ago. However, I didn't have my drag radials on that night. Is a 2.2 60' not at least semi-respectable for street tires? Maybe the mph is right, but it's just toying with me being so close to 100.
                    -Travis
                      I put down a 2.2 60' on stock suspension and stock size tires. I would say its pretty respectable. I have seen alot of cars go faster with this kind of 60'.
                        if thats the case why can i hook a 1.7 60 foot and only run a 13.5 with a 98 mph trap
