Finally got some times with the 3.73's - FirebirdV6.com/CamaroV6.com Message Board
  • Finally got some times with the 3.73's
    Im a bit disappointed!! i was expecting some 15.5-15.6's but only managed a 15.8, BUT, the air was REAL bad tonight, there was a LS1 TA with a 2800 Vigilante, borla exhaust, Nitto's and some other stuff that ran a 13.9! so that tells you how bad it was, i think im gonna have to stop going to this track and make a trip to houston or san antonio
    i think you need to get some nitto's no way you are hooking.
    Hell the M5's down here cant hook with 3.23's on stock tires. you should be able to pull a 1.9 60' i am sure
    what were your 60'? hell I have pulled 2.0 on stock tires in my auto with 3.42's
      i was hooking up fine, its just that the air was so bad i didnt have any HP, i had a 2.15 60' leaving at 2750, i tried upping the launch RPM and it just wheel hopped, if i could leave about 3500 it would probably go 2.0's out here, i dont have stock tires, i have bridgestone potenza RE-730's, they hook pretty good
        which track, temple or RCR?
        AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
          River City...
            you go on fridays?
              ive never been, just wanna go for better times, i will go this winter sometime hopefully, ive been to sealy before but it sux cuz its only 1/8th mile and theres no way to go around the water so you spin...
              [ June 20, 2002: Message edited by: WickEdSix9838 ]</p>
                go to RCR on wendsdays, only 15 bucks to get in, and you can go as many times as you want. opens at 6:30 and lasts til 11. ive went the past 2 weeks and got about 7-8 runs in each time, letting the car sit and cool for a bit, too.
