Did you guy notice any faster times by puting a one piec drive shaft in.
drive shaft
THe gains are not noticeable, like in tenths, but you WILL gain from it.
You go from around 23lbs of rotating mass to around 12.
It helps performance and durability. Two piece DS's can break VERY easily.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
I do know that Magnus knows A HELL OF a lot more than I do, however... I have heard of people getting noticable gains from the alum driveshaft..
it frees up horsepower going to the rear wheels and it is a lighter rotating mass. However, its not going to be a HUGE difference from what I hear, but maybe unnoticeable is a bit harsh.
I noticed quicker rev's
Which is related to reducing rotating mass.
It seemed quicker off the line and higher rpm's but nothing in the middleRace car - gone but not forgotten - 1997 firebird V6
By unoticeable I'm talking tenths.
It's very hard to put a # on the gains from going to a 2 piece DS to a single lighter piece. But it is fact that you WILL gain at least something because of the less rotating mass.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
The rough "rule of thumb" I always hear (but have never proven/disproven myself...) is 100 lbs weight reduction = .1 second improvement in e.t.
And that eliminating 10 lbs of rotating mass is equivalent to taking 100 lbs off the car... So taking 10 lbs off the rotating mass should give you maybe a .1 improvement.
I think the diameter of the rotating mass makes a difference too, though you never hear that. Did you ever try to spin a merry-go-round with a kid in the middle, vs. a kid on the outer edge... It was easier when the kid was in the middle.
So the driveshaft diameter is pretty small to start with, and the weight is near the center. May not make as much difference.
At the same time, the driveshaft spins more rpms (3-4 times depending on rear gear ratio) than the wheels, so it may be about the same net effect as taking weight off the wheels after all.
I have an aluminum 1 piece being delivered today to replace my steel 1 piece... Just one of those things I thought I needed. :D
In your case, the 1 piece will be much more reliable, so the peace of mind would be well worth it, if nothing else.\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
i just put an aluminum 1 pc in my bird..i notice a gradual gain right outta the hole. i also spin less outta the hole too?? does this make sense to anyone?
or i could've just gotten a sh*t load better at my launches :D94 3.4L A4 white t-tops<br />moroso cai<br />3\"hi-flow pacestter exhaust<br />b&m shift kit<br />catco cat<br />01 T/A rear w/ 3.73\'s and posi<br />1 pc aluminum ds<br />blacked out signals
<blockquote>quote:</font><hr>Originally posted by greencamaro:
thank for all of the help. will it fit rit in with no prolem ar what will i have to byt new u joint.<hr></blockquote>
It should go right in, without having to buy anything else.\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....3 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.3 days ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
