what is the best way i should take off from the line in my auto should i rev it, take it from 1st on up or just slam it down from drive.
also what should my psi be at i have some dunlop sp sport 5000 zr tires 245/50 16's on the tire it says max psi 51 but what should i run for the track
My ride: <br /><a href=\"http://members.cardomain.com/youngdeezy\" target=\"_blank\">http://members.cardomain.com/youngdeezy</a><br />98 Firebird 3.8L A4<br />Mods:80 seires flow master muffler<br />dual exhaust 3\" pipes,whisper lid<br />k&N filter,3.42 gears and LSD, 180 thermostat, free ram air mod & 1/2\" raised air box + some apperance mods<br />1/4 mile 15.8 @ 85mph<p>I\'ll see you in the traffic...
<blockquote>quote:</font><hr>Originally posted by YounGDeezY: what is the best way i should take off from the line in my auto should i rev it, take it from 1st on up or just slam it down from drive.
also what should my psi be at i have some dunlop sp sport 5000 zr tires 245/50 16's on the tire it says max psi 51 but what should i run for the track<hr></blockquote>
i found the best thing for me was to stall it up as high as possible then go, but some cars are different so i would say go to the track and test it yourself, thats the best way to learn what is best for your car.
as far as what psi to run in your tires. i had my stock 235's at 40 psi at the track. i found that worked best for me, but like i said thats just my car though. i say just go to the track and have fun with your car.
<b>2000 Firebird </b><br /><i>old setup </i>- Automatic Whisper lid, Borla catback, shift kit w/ V8 servo, 3.42 gears w/ LSD, PI 3000 converter, <br /><br /><i>14.703@90.92, 2.01 60\' </i>(intake and exhaust)<br /><br /><i> new setup </i> swapped over to LS1 413.9rwhp/398.7rwtq<br /><a href=\"http://www.thunderracing.com\" target=\"_blank\">www.thunderracing.com</a>
Good weather will play one of the biggest roles when going for that best E.T. All cars are different, my car liked being tached up to about 2k and being flatfooted from there, resulting in alot of 2.0x 60's. You can't just jump in the car and expect a perfect launch. PRACTICE. I used to run my stock Eagle GA's with 40 psi in the fronts and 28-30 psi in the rears.
Good luck!!!! The key to quick times in our cars is in the 60' time.
With the 60' on stock suspension 2.1 is very possible, so aim for that as your goal. For me (experiment to find the best for you) I found keeping it in D, not (D), and stall the converter to about 1700-1800RPMs. When you're ready to go release the brake and ease into the gas, don't just pound the pedal (unless you want to spin tires) and you should get between 2.12 - 2.20 no doubt. Also make sure you have 3.42s and LSD. [img]tongue.gif[/img]
